Question about Samsung Wireless Headset for Bluetooth-Enabled Cell Phones - Gray
How long does it take to be fully charged - Samsung Wireless Headset for Bluetooth-Enabled Cell Phones - Gray
Pedego hub motor jumped and then no power. Fully charged battery and have lights showing fully charged battery.
Please give us a call so we can fix the issue! (800) 646-8604
Thank you,
Pedego Team
Oct 01, 2012 | Motorcycles
I have a Rascal 305. How long should built-in charger run to fully charge batteries. Mine only charges about one hour at 3.5 amps (on meter on back) before shutting off. What should charging current be,...
moleman If the batteries are fully depleted then the on-board charger will not pick them up and charge them to full strength. It is not designed to charge very low batteries. If the batteries stayed fully depleted for a period of time you will have to replace both of them. You should never fully discharge your batteries. The battery level gauge on your chair should be used to determine when to charge if it is the red recharge overnite. Get into the habit of recharging overnite if you use the chair daily. Always store the chair fully charged and if not used weekly charge once a week. Never leave the charged plugged in more than 18 hours. The chair only operates on about a 5-6 volt range from about 21-26 volts. If you are in the red the voltage is down to about 20-21 volts. Hope this helps you
Sep 29, 2010 | Health & Beauty
After charging my MP3 player it appears fully charged but it will only play for about an hour and the battery runs down. i have recharged it again, same thing. now what?
The very first time you charge your battery YOU MUST CHARGE IT FULLY!!! If you didn't, that is probably the problem.
Also, even if you charge the player for just a couple of minutes it will APPEAR to have a fully charged battery when it actually doesn't.
Most portable media devices require at least 20 minutes to an hour to fully charge whether the screen shows that it is fully charged or not.
Jun 30, 2010 | SanDisk Sansa e250 MP3 Player
On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
Dec 13, 2009 | JUMP START SYSTEM
How to the Zen Mozaic player is fully charged
once your mp3 player gets fully charged you can see in the screen of your mp3 player showing "full" near the battery symbol.
Dec 08, 2009 | Beond Creative Technology Zen Mozaic MP3...
Battery fully charged
thier is a pic of a batterty in the bottom right corner, it will be fully green when charged. otherwise it will be flashing.
Jun 11, 2009 | SanDisk Sansa Clip MP3 Player
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Battery will not fully or will not charge
Whenever you first purchase a device you must charge the phone fully otherwise if you charge it partially an then use it it will never charge good. You may need new battery see if youe warranty covers it \. If you are within 30 days of purchase you can exchange it at no cost!
Sep 04, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Samsung Wireless Headset for Bluetooth-Enabled Cell Phones - Gray Logo
18 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
