Question about Electrolux Washing Machines
E44 = ?
Hi i have run the diagnostic mode and found e44 on my machine. I wonder anyone know the error code stands for? Many thanks!
  • bennysia28
    bennysia28 May 08, 2013
    My machine is Electrolux Front loader ewf1083.
  • Official Brand Answer
  • 4,342 Answers
Good Morning bennysia28 - Typically, error code E44 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Posted on May 23, 2013
  • 1314 Answers
SOURCE: Loud winding sound
that's normal should sound like a lear jet engine cranking up load whining sound is that what your hearing mines been doing it for about 9 years high speed spin is 800 rpm let me know if that's not the sound besides the control bd not much there to go wrong
Posted on Jan 01, 2008
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
Posted on Sep 20, 2008
SOURCE: Error code F-08
Hi
Did you fix this? I have the same issue.
Posted on Oct 22, 2008
SOURCE: AEG 88730 error codes
error code c9
Posted on Feb 22, 2009
  • 6277 Answers
SOURCE: Hi Folks: I have an
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I suggest you try the manufacturer's web site direct for a more technical manual? You may find, however, that it will supply only to its own service engineers but good luck anyway.
John C.
Posted on Mar 10, 2011
Testimonial: "Thanks John: Ya, I think AEG only supplies tech info to registered service techs:( Had leakage current to ground (non-GFI circuit) = solved"
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Apr 05, 2016 | Electrolux Washing Machines
EWF 1704 erro 41
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
E41 - Door open
Possible causes:
Dado
Sep 14, 2015 | Electrolux Washing Machines
My zanussi washer is coming up with error code 40 anyone no what it is
Dado
Aug 27, 2015 | Zanussi Washing Machines
How to do with E40 code of Electrolux EWF 1074?
programme):
E41 - Door open
Possible causes:
Dado
Aug 24, 2015 | Electrolux Washing Machines
Jet stsem no water comming in and flahing erreor 40
programme):
E41 - Door open
Possible causes:
Dado
Jun 14, 2015 | Zanussi Washing Machines
What does e44 means
you will have to google the make/model error e44 to find that out as we have no info from you
Mar 10, 2015 | Washing Machines
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Mar 03, 2015 | Bosch Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
programme):
E41 - Door open
Possible causes:
Dado
Feb 24, 2015 | Electrolux Washing Machines
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
programme):
E41 - Door open
E44 - Door interlock sensing circuit faulty
Possible causes:
Dado
Aug 02, 2014 | AEG Washing Machines
Washing Machines Logo
139 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
