Question about Apollo 835 Circuit Board ( Replaces 833 Board)
Apollo 833 board - Apollo 835 Circuit Board ( Replaces 833 Board)
Comfortaire pump 833
The Comfortaire model 833 has a 3.15 amp fuse next to the power cord. Check to see if it has blown.
May 12, 2014 | Furniture
My drive fall form table i was tryed it is not working and not able to read my data that drive needle getting tick tick sound coming what can do?
The continuous "tick tick" normally means low power on the device.
Means: Case board broken or hdd logic board fault.
Possible solutions:
- Try to change usb port and usb cable.
- If you have an usb power adapter try to connect it JUST for some seconds to see if the disk spins.
Warning: you can burn your disk because the classic usb omputer port use a 500mA max power while an USB A/C normally can offer up to 2000mA.
- Buy a cheap 2.5" hdd case and put on it your 160gb hdd because the board of the Apollo could be broken. In this case check before buying if you need a SATA or a PATA interface.
If nothing changes, sorry, your hdd is probably dead.
Sep 13, 2012 | Imation Apollo Portable - Hard drive - 160...
Threading singer stylist 833
sewusa.com has some threading diagram
or try singer
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 833) & click search
May 08, 2012 | Sewing Machines
How do we remove erasable white board marker from the apollo screen?
With Windex, just use a wet rag afterward to make sure the ammonia is not left behind. If the screen is stained that is a different issue as you will have to use a cleaner that actually removes some of the screen, but doesn't eat through it entirely.
May 07, 2010 | ACCO Brands Apollo Projector Screen
Mother board drivers
i found the driver in Gigabyte site
my board is 81g1000mk, not big100mk
Jan 05, 2009 | Intel Motherboard
Need help on using a sony RMT-833 remote control unit
The Sony RMT-833 remote is for a Sony Camcorder - see http://www.replacementremotes.com/store/images/RMT833.jpg
I think you mean the RM 833 remote - if so try eBay as listings there suggest it works with Number: RM-833 Compatible with TV Models: KVX250, KVX2501D
Hope this helps
Sep 25, 2008 | Sony RMT-833 Remote Control
Apollo 2600 printer installed ok, but wont print
I don't believe Vista is compatible with Apollo any more. I know OS XP will work
Jan 30, 2008 | HP Apollo P2600U InkJet Printer
Apollo 835 Circuit Board ( Replaces  833 Board) Logo
32 people viewed this question
Top Apollo Home Security Experts
Lawrence Oravetz
Are you an Apollo Home Security Expert? Answer questions, earn points and help others
