Question about Canon MP280 All-In-One InkJet Printer
Print on black envelopes - Canon MP280 All-In-One InkJet Printer
  • Canon Master
  • 32,281 Answers
There is no way of printing on black paper. You need to print on white envelopes.
Posted on May 08, 2013
I use a Dell 3110 cn printer. There were black splotches whenever I printed envelopes.I had a serviceman look at it to no avail so I changed the black toner cartridge. I am now getting blue splotches. ...
when you print envelopes you have to choose the envelopes in the printer settings then only machine knows that envelope is printing. when you don't select envelope in printer settings when you sent a print, the printer knows the a normal paper is coming through. the difference is that the envelope is a bit thick the normal paper. when envelope is selected in printer properties then the printer adjusts its settings to print on envelopes.
Jan 06, 2011 | Dell 3110cn Laser Printer
Ink is smudged on envelope. How do I stop that from happening?
i bet you're printing in Black,
what happens is when black is selected, the 3 colored drums lift up 2 mm annd only the K drum is engaged, amd there is no static in the transfer belt under the CMY drums.
envelopes have air in them and can bounce along the bely after the black has printed, and seeing the toner is powder and not yet fused on, the toner touches the cyan drum as the envelope hits the fuser entry point as well as dragging on the Left transfer belt Blue lift handle(take out the belt and spring the handle off).
If you open the lid in this print mode, and lift out the cyan drum, turn it over and pull back the cover for the OPC drum, you will see the black toner on the green drum.
FIX 1. In the art work place a tiny dot of yellow. this will run the print mode in color and enagage all the drums. gaurantee your print will be fine, and know one ever sees that yellow dot.Problem is, this then runs down your CMY drums for black only printing.
FIX2.
If you have a later machine, downlaod iQueue from Xante.com (free) fantastic software. and get the machine updated with the latest X1.11 firmware from your dealer.
This allows with iQueue, to set the machine to print Black only, and you run the machine without the CMY drums installed....it works, it's great...
Aug 10, 2010 | Xante Ilumina Digital Color Press Printer
LEXMARK X1240 WON'T PRINT ENVELOPES
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Jun 01, 2009 | Office Equipment & Supplies
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
Envelopes print in color and I want black only
First you need to change the settings in the software you are trying to print the envelope. Open the program (for example MS Word), go to the option from which you print envelopes and labels. Set the font color to black, not "automatic", and in Word, click "default", which sets the color as black rather than allowing the printer or its software to select the wrong color. Then try to print on the envelope and let us know if you are able to print the envelope in black only.
Apr 20, 2009 | Office Equipment & Supplies
Won't print envelopes in black
Apr 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
Printer has suddenly stopped printing envelopes
Just fixed it thanks to Lloyd at Lexmark.com Go to Technical Support > LIVE CHAT. To print envelopes all I needed was to check the print in "Black" only button. Under Quality make sure the Print Color images in Black box is checked, select Apply and OK.
Jan 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Canon MP280 All-In-One InkJet Printer Logo
13 people viewed this question
old marine
old marine
