Question about Hansgrohe Metro E Single Handle Deck Mount Roman Tub Faucet Trim Lever Handle
Adjust handle stop on Metro high arc
I just installed this faucet and the handle hits the backsplash when I push the handle back for hot water. How do I adjust to bring the handle forward? I took the handle off and see some plastic adjustment but cannot seem to rotate it. Help!
    Scholar:
  • 72 Answers
The Metro Higharc does have a green ring on the cartridge to limit the amount of hot water that can pass through the faucet. You can adjust this green ring to limit the handle swing but it will limit the amount of hot water you can get form the faucet. To adjust the green ring you will need to first remove the handle then you can remove the screw from the cartridge stem. Then the green ring will slide up over the stem so you can turn it to a more limited position. You should be able to see +/- marks on the ring that will help indicate where and how much you are adjusting. If you need further instructions feel free to contact me at Hansgrohe Tech 1-800-334-0455 press 2 for Tech and ask for David Scarborough. I'll be happy to help.
Posted on May 08, 2013
    Top Expert:
  • Hansgrohe Master
  • 42,705 Answers
Is it possible that you have installed the faucet incorrectly . Loosen it off and turn 90 degrees facing you so that one way is cold the other way hot.
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Drain handle comes out of the back of the faucet and hits the backsplash. Is it susposed to come out at an angle? Not covered in installation instructions.
    Yes on this faucet the drain knob is susposed to come out at an angle. There is no way to stop it from coming out at angle.
    Feb 12, 2011 | Danze D223121 Antioch? Single Hole...
    We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
    u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
    Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
    Why is my hot water so low on pressure with a single handle faucet. Parts have been replaced yet pressure reduces to less than half when trying to get enough hot water to shower and rinse. Could this be...
    Remove handle and adjust the rotational limit stop. As you move the rotational limit stop counter clockwise it will increase more hot water in the mix.
    Remember where it is before starting and pull in back onto shaft out of place so you can move it a little and put back into place. It should have marks to line up to get you different setting's. Just put handle on and turn on and check for desired hot setting.
    The only way to adjust this is to pull it out of place due to it fitting in place like a gear and reinsert and check water.
    Jun 19, 2010 | Delta & Single Handle Shower Faucet
    Moen T910 Kingsley two handle, whirlpool tub faucet. The hot water handle only puts out lukewarm water. The water heater is turned up and all the other faucets in the house put out scalding hot water.
    if you remove the hot water handle on the faucet you can adjust the stop. if it is a newer faucet it has a built in scold guard. the directions should tell you which direction to move the stop to get hotter water
    Oct 22, 2009 | Moen T910 Kingsley Deck Mount Whirlpool...
    Not enough hot water, has to do with a shower valve
    Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
    Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
    temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
    Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
    Hi folks, seems stupid, but I'm changing the cartridge on my american standard kitchen faucet. If I line up the holes on the botton of the cartridge with the holes in the fixture, I don't have the ability...
    Most likely you need to adjust the hot limit safety stop which restricts handle swing to limit the high temp of the water and avoid scalding... check out this link to the install manual for your faucet. Also includes detailed diagram of cartridge alignment just in case you need it.
    http://www.americanstandard-us.com/Assets/pdfs/as/install/Install_1859.pdf
    Hope this helps, Tripp
    Dec 13, 2008 | American Standard Kitchen Faucet 6310 020...
    Hansgrohe Metro E Single Handle Deck Mount Roman Tub Faucet Trim Lever Handle Logo
    91 people viewed this question
    Top Hansgrohe Home Experts
    Shehu Pro
    Shehu Pro
     John
    John
    Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
