Question about VeriFone vx670 new wifi wireless M267-012-11-USA
Verifone vx670 when processing credit card comm error 1B keeps coming up. Why is this happening.
  • 3 Answers
SOURCE: Inserting Paper into Verifone Credit Card machine
Just pop the lid with the button on the side of the terminal and drop the roll in with the paper coming out toward you as you face the machine. Close the lid and rip off excess. There is no need to feed paper through anything.
Posted on Jan 24, 2008
SOURCE: Verifon credit card transaction printer FONTS
donde puedo conseguir el teclado de la terminal tengo dañado el boton del enter
Posted on Sep 05, 2008
nayabkhil
  • 31 Answers
SOURCE: no card for transation
One if not too late. This terminal is out of compliance with running credit cards through. But if your merchant service provider is allowing you to continue then at the main screen just:
Hit 1
Then enter CC # and enter or function.
Then EXP date of the card then function.
Then Address and or ZIP of the billing for the cardholder
then enter and it should process it VIA dial approval line.
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: My Wireless vx670 verifone credit card machine is
Depending if your terminal is on the IDLE PROMPT SCREEN or the VMAC SCREEN... you would select SETTLE on your terminal. If there is a password it should 1 alpha alpha 66831 (default pwd by Verifone). Then proceed with confirming the totals on the screen by pressing the GREEN "Enter" KEY
Posted on Apr 29, 2010
puertobori
  • 7733 Answers
SOURCE: Problem with the VeriFone VX570 Credit Card
You can get the Installation Guide HERE.
You need To Install/Replace MSAMs where all previous information is stored:
1 Remove the power cord and/or battery (see Smart Battery) from the terminal.
2 Place the terminal upside down on a soft, clean surface to protect the lens
from scratches
3 Remove the MSAM compartment door screw and rotate the door up and back
to access the MSAM cardholders (see Figure 11).
4 Remove any previously installed MSAM card by sliding the card from the
MSAM cardholder.
5 Install an MSAM card by aligning the card and carefully sliding it within the
guides on the cover until it is fully inserted (see Figure 12).
Contact: VeriFone Systems, Inc.
2099 Gateway Place, Suite 600
San Jose, CA 95110
USA
Tel: 1-800-VeriFone (837-4366)
Main Tel: (408) 232-7800
Main Fax: (408) 232-7811
Posted on Jan 18, 2011
We have a verifone terminal (not sure what model but I could find out) that keeps getting the tamper error. It's happened 7 times in the last 8 months. We've switching merchants which helped for a while...
Your problem presents more questions. Has your machine been refurbished during this time? Is the location in a restaurant or bar? Does the merchant turn off the machine daily? Does the machine get dropped often? These are all things that may cause the machine to go into tamper error. Please call Frank (775)338-6634
Jan 10, 2015 | VeriFone VX570 Credit Card Terminal (Dual...
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
How do I reboot verifone vx610?
UNLESS YOU DROPPED THE TERMINAL, THIS CONDITION IS CAUSED BY A DEPLETED INTERNAL BATTERY, WHICH MUST BE REPLACED fix Verifone TAMPER message for $32. Free return shipping
Apr 04, 2012 | VeriFone VX 610 Credit Card Terminal...
Verifone vx570 checksum error
Maybe you have a corrupted program/application. Call your credit processor for the download process of your application. But before downloading, don't forget to batch and settle your unit if you can. Then clear all the old program in your machine. I hope this will help you. if need more help call (775)358-2922 ask for Randy. Thanks
Jan 29, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
** TAMPER ** VERIFONE VX670 QD0012A1 03/11/2009 verix COPYRIGHT 1997-2009
VeriFone provides a clear tamper application to its service centres. you would have to locate a service centre closest to you to have that error cleared.
Sep 08, 2010 | VeriFone VX570 Credit Card Terminal (Dual...
My Verifone vx670 needs to release and reestablish it's IP address frequently for wireless communications and after taking a vacation I forgot the key combinations to perform it!
I also need to change the network settings on my Verifone VX 670 as i have recently installed a new wifi connection. Any help would be appreciated!
Aug 31, 2010 | VeriFone VX570 Credit Card Terminal (Dual...
VeriFone Vx670 can't download shows error open comm fail. Modem open failed. How can i fix this? Thank you
they have a 3 step process in setting up the hand held device I have included a link to the page http://www.dcrs.com/pics/db/document_library/000158.pdf one major priority is to have a secure wireless connection on site, not a shared one
Mel
Jul 16, 2010 | Computers & Internet
The machine will not process credit cards.
contact your processing company
On your monthly statement, it has tech support phone#
http://www.gorillapaper.com/verifone-terminal.html
Oct 16, 2009 | VeriFone (M19755014US1) Magnetic Card...
COMM ERROR on Verifone 3750
This could be a number of things.
#1 do you have DSL internet service? If so do you have a DSL filter between the jack and your terminal?
#2 Do you have digital phone service? Vontage or Comcast will cause this problem . Especially upon batching out the terminal.
#3 Check the blind dial setting within the other setup option. This option is buried, so it will require a phone call to Merchant service Provider.
If none of these work, then it is time for a new service. Place a call the Heartland Payment Systems Credit Card Processing and change your card service provider. The only card service provider that has a merchant bill of rights and field service techs (for free).
Nov 17, 2008 | VeriFone (M19755014US1) Magnetic Card...
VeriFone vx670 new wifi wireless M267-012-11-USA Logo
50 people viewed this question
Top VeriFone Computers & Internet Experts
Martyn01202
Martyn01202
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
