Question about Sharp Actius A100 (PCA100) PC Notebook
Laptop doesd not boot
As it doesnot boot I ran the recovery disk to reload the program burt it still hangs. Iam told i would need to reoplace the harddisk as it was having bad secotr. Anyone can help me with a solution that i can try or can suggest where i can find a compatabile harddisk of 3.2 gb which fit the actius A100 PC
  • 3 Answers
The first thing I will suggest you do is check the bios version in your laptop and make sure that it is up to date. The reason: IT will be hard to come by a 3.2GB hard disk drive today. If you find one then it is going to be either refurbished or you pay a lot for it. Alternative: Get a bigger size hard drive like the 20 GB suggested by the last solution. But before then visit sharp website and check out the bios update for the model that you have-PCA100,1086,30,00.html Follow the instruction to update the bios. If you are a complete novice then I will suggest that you do not attempt to this on your own as this may screw up your computer. In any case, you can follow the instruction to flash the bios and then you can install the new hard-drive and follow up with OS restore, instruction for this is also available on sharp website Steps from Sharp?s website: How to recover the operating system. Note: All data on drive C: will be lost if you recover the operating system. After hitting the power button, look for the prompt to "press F2 for setup" and press F2. Scroll to the Boot Sequence option and hit Enter. Highlight the CD-ROM option and press the space bar until it is shown at the top of the 3 choices. Press Esc until you are in the Exit screen. Put Recovery Disk One in the CD-ROM drive. Chose to exit saving changes and the system will boot to the recovery CD. The recovery program will walk you through the rest of the process. You can choose to recover drive (partition) C: or both C: and D:.
Posted on Aug 11, 2007
  • Michael Banjo Aug 11, 2007
    My Link above was truncated by the system
    here is the correct link on 2 lines
    New Friend:
  • 83 Answers
You can put up to a 20gb drive in this machine,,,,the other thng you can do is actually format your drive, do not quick format as this will not map bad sectors,, then I would use the restoration disk to recover your operating sytem and programs, and do all available updates,,,,good luck i hope this helps...
I erased part of a preloaded program and now I get a multicolored spinning wheel occasionally for my pointer so how can I reload the program that came with my Apple computer
It sounds like you need a boot disk.
You can try to boot holding Command + R and go into recovery mode. If it's too old, you'll need to download the recovery tool from apple's website.
Feb 20, 2014 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
I have problem in my deelld620 when iam deleting local diskC IT CANT ACCEPT TO DELETE
You cannot delete the C: drive when you are running in Windows, since that is where the Windows installation is. If you want to reinstall Windows, then you need either the recovery disk, or to hit the hotkey during boot to boot from the recovery partition.
Sep 20, 2013 | Dell Latitude D620 Laptop (Latitude-C620)...
My laptop not getting started and if i try to boot from windows setup its getting hanged
Try running the Check Disk Utility. Hopefully your operating system is still there to run the check disk utility. I do see where you say you ran a format which might have wiped it out.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 04, 2012 | HP Compaq Presario V3000T Notebook
How to restore my toshiba a105-s2236 laptop to factory setting with out a disc
If your Toshiba has a Recovery Partition on your disk drive, then you can boot the system and see which function key it says to hit to get into recovery. Some system will have an option to get into recover under the Programs list. Click Start/Programs and see if there is a recovery there. If all fails you will need an Operating System Disc to reload.
Mar 28, 2012 | Toshiba Satellite A105 Notebook
My acer laptop turns on, then tells me to contact the systems administrator. If I try to continue it shuts down. at one time I recall reading that the files have been currupied. is there anything I can...
It sounds like the Windows boot files have become corrupted. That could happen for several reasons, but if you're willing to just reformat/reload the operating system, we're only concerned with one of those reasons.
There are some viruses that can corrupt boot files. If that's what happened, then reformatting/reloading the OS will take care of it.
On the other hand, it could be that your hard drive may be failing. When you reformat/reload, the Windows system will tell you if it finds errors on the drive.
The following is from the Acer manual for your machine as to how to access the BIOS and enable a hard disk recovery:
To activate the BIOS utility, press during the POST; while the notebook PC
logo is being displayed.
Boot sequence
To set the boot sequence in the BIOS utility, activate the BIOS utility, then select
Boot from the categories listed at the top of the screen. [You should set the CD/DVD drive to be the first boot device, in case you need to reload from a DVD]
Enable disk-to-disk recovery
To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the and keys to set this
value to Enabled.
[End of manual quote]
If you're not able to restore from the hidden partition on the hard drive, which may happen if the drive is damaged, then you'll have to try to restore using a Windows DVD.
Hope that's helpful.
Jan 12, 2011 | Acer Aspire 3680 Laptop
Laptop will not boot when turned on
Go into bios and make sure that your cd player is set up as the first boot up device. Then insert the disk, reboot and follow the prompts to install the OS. When thru get the drivers you need and you are good to go!
Sep 11, 2017 | Averatec 3150H Notebook
I bought a hpDV7US laptop at work. a customer changed the password i need to know how to reset the password. I tryed hiting the f10 key as soon as i turned the computer on. I put in a new password that way...
There are several free Password recovery programs available for download on the Internet. The best ones allow you to change the password to a new password of your choice. Google "password recovery"
Jul 08, 2009 | HP Pavilion dv7-1240us Notebook
Doesn't want to start windows
In fact, that is the troublshooting technique when your computer does not boot up, insert the recovery disk and allow it to reload. The reload shoud be on the screen, otherwise you have a bad monitor and that's a different subject..Now why it happened is what we need to work on..did you do anthing like download programs are anything prior to this happending? Let me know who the re-install goes...since its refurbished it could be anything at this point.. let me know if you have any quesitonsl
Please rate this solution.
Mar 19, 2009 | Gateway MX6931 Refurbished Laptop - Intel...
Toshiba A60 Not Booting
You might want to run a harddrive diagnostic test. You can find bootable iso's on the harddrive manufacturers website.
May 11, 2008 | Toshiba Satellite A60 Notebook
Sharp Actius A100 (PCA100) PC Notebook Logo
93 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
