Question about Emerson Televison & Video
Screen keeps turning off
Cuts on then go's to stand by
    Top Expert:
  • Emerson Master
  • 74,383 Answers
Check its back-light inverter board and backlight CCFL lamps. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there.http://electronicshelponline.blogspot.com/
Posted on May 08, 2013
My2002 R1 won't start no green neutral light when I turn the key the yellow check engine light lights up
Hi, Kevin the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
neutral light wont come on when in neutral and wont start with kick stand.
No neutral light bike won start
Yamaha YZF R1P Service Manual
OEM parts for Yamaha
Yamaha YZF R1P Owner Manual
Sep 22, 2017 | 2002 Yamaha YZF-R1
Triumph trident 93 model side stand works as it should but warning stays on with stand up john
Hi, John either the switch is faulty or the circuit is grounded to the light that being said the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Side stand bypass
Sidestand Clutch Safety switch issues
Triumph TROPHE Service Manual Page 2
http://www.triumphestore.com/
http://mybikemanuals.com/triumph/uncategorized-triumph-owners-manuals
May 09, 2017 | 1993 Triumph Trident 900
1995 KLE500 Kawasaki: neutral blue light doesn't show and when clutch is released to engage in gear, engine cuts off
Hi, Ishmael the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Kawasaki KLE 500 dies when clutch is released
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/66113-gears-wont-engage.html
Kawasaki KLE500 Service Manual
OEM Parts for Kawasaki
http://www.kawasaki-techinfo.net/searchOM.php?view_lang=EN&spec=OC&
Apr 11, 2017 | kawasaki KLE 500 Motorcycles
Hi, H650, working fine, then erratically just stop, seems electrical problem, side stand switch were suspicious, took it off and bridged the wires, the same problem, Thx
Hi, Tamas the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Runs stops starts backfires
Engine turns off all of sudden when riding
Kawasaki Ninja 650 Service Manual
Kawasaki Ninja Owners Manuals
Apr 01, 2017 | 2008 kawasaki Ninja 650R
My zx7r, ive got no Ignition or Neutral light, I have replaced the ignitor unit,the clutch switch, the battery,the side stand switch,the junction box, the fuel pump and still no ignition? I took off my...
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
http://www.zxforums.com/forums/zx-7r-forum/50874-zx7r-won-t-start.html
my bike will not start zx7r
KAWASAKI NINJA ZX 7R Service Manual
Apr 04, 2017 | kawasaki Ninja Zx7r Zx9r '94 To '04
My tv keeps saying stand bye and it won't cut on all its doing is making the click noise and the red light keep blinking
Try unplugging it for 30 seconds and see if it resets. If not, take the model # and get on the internet for the manual and go to trouble shooting page. It should answer your questions
Feb 13, 2013 | Televison & Video
My screen kept turning blue for couple of weeks and now i can't get my television off stand by mode
unplugged the tv for a while then re plugged it and power it on, lets see weather it works normal. if doesn't work unplugged it again then remove the rear cover then look for a bulging capacitors in the power supply board.
Sep 27, 2012 | Televison & Video
1997 Suzuki Intruder VS800...starts, runs, stalls
Intruders Alert
Total Motorcycle Forums
Suzuki VS700 Service Manual
OEM parts for Suzuki
Suzuki VL800 Owner Manual
May 12, 2017 | 1997 Suzuki VS 800 Intruder
LG 32FS2ANB keeps going into stand by mode
Recheck your remotes settings most likely it's turned on for stand by sometimes going into your settings and going back to it's default settings helps.
Jan 28, 2012 | LG Televison & Video
I own a 2008 Hyosung GT 650 and never had any issues until now. At first all I had to do was pull back on the clutch lever and start the motorcycle...no problem. Then I had to let off a little bit to get...
Hi, Paul_nason the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
2008 GT650R Wont start
Troubleshooting Starting Cranking Problems on Hyosung Motorcycle
HYOSUNG GT 650 Service Manual
https://www.alpha-sports.com/Parts/H_GT650R.htm
HYOSUNG GT650 Owner Manual
HYOSUNG GT650 PARTS CATALOGUE Parts Catalog
May 02, 2017 | 2008 Hyosung GT650
Televison & Video Logo
19 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
