Question about Blazer GB2001 Self-Igniting Butane Micro-Torch
Butane torch weakening flame, loosing gas pressure
    Problem Solver:
  • 3 Answers
Could be due to the fine gauze in the nozzle becoming clogged due to maybe not using good quality gas refills?.
Posted on Aug 13, 2013
  • John Griffiths Aug 13, 2013
    Could be due to the fine gauze behind the nozzle becoming partially blocked due to using cheap gas.
  • Chad Smith
    Chad Smith Jan 14, 2016
    How can we get new filters and schematic for the gb 2001
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
Gas bbq
flame running back is an indication of insufficient gas pressure or flow. check and adjust the regulator and ensure that there is no blockage in the jets.
May 14, 2013 | Grilling
My Ronson butane torch won't light
probably has bad fuel in it. get new stuff. cheep fuel sucks.
Mar 06, 2013 | Cars & Trucks
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
Several new torch lighter, filled with butane, has spark, wont light.
adjust the fuel output , it is easiest to do by holding the button down while lighting the flame with a seperate lighter and then setting the flame on the lighter that does not ignite proper, also take into account that the temperature of the lighter by being held in your hand for a while or by being in your pocket can have a great effect on the pressure of the buttane being expelled.
Jan 21, 2011 | Garden
The Blazer micro torch does not ignite (no hissing sound for the gas either) and we did fill it with butane? Any suggestions - have had it for awhile - maybe it needs new flint? or whatever ignites it....
Hi. Get a piece of very fine wire, hardware store is a good source, and run it into the nozzle. Chances are that the nozzle is clogged. Once it is hissing again it will ignite unless you also need a new flint. J.
Jul 08, 2010 | Omega Blazer Self - Igniting Butane Micro...
Brand new Weller Mcm Magna Lite butane torch does not light
If this is an itty ***** torch, The fuel is very sensitive . Too much screws up the air fuel ratio so try turning it way down and after the tip has heated up, you can increase your flame. Good Luck, Ned
Aug 27, 2009 | Weller Mcm Magna Lite Butane Table To
Dunill lighter - how do I fill it with butane?
  1. Ignore that other load of tosh.
  2. Do not refill your lighter immediately after using it. You should allow enough time for the lighter to cool off.
  3. The flame height adjuster on the bottom of the lighter should be set to minimum by turning CLOCKWISE with a small screw driver. The smaller, usually Phillips head, screw is for dismantling the lighter and should not be touched. The adjusting screw is a larger screw with a standard (slot) head. Some lighters come with a key to turn the adjusting screw. Some models have an adjusting wheel that requires no screwdriver. Please DO NOT FORCE the adjusting screw. If it is hard to turn in one direction this most likely means that the adjustment screw is already at the (-) or (+) limit. Try turning the other direction.
  4. Push the refilling valve with a screwdriver to let out the air inside until no hissing sound is heard. Hold the lighter away from your face. Air inside the fuel tank prevents butane gas from being injected into the tank and causes the lighter to malfunction.
  5. ALWAYS refill the lighter in an upside down position to avoid injecting air into the lighter.
  6. Shake the butane gas refill can, press the stem of the refill can directly onto the refill valve on the bottom of the lighter. Keep them in a straight position and let the gas go into the lighter for about 5 seconds. Repeat for a shorter period if needed.
  7. Allow 3-4 minutes to let gas and lighter components reach room temperature.
  8. Turn the flame adjuster counter clockwise to reach the desired flame height.
  9. Hold the lighter away from your face and body and ignite it carefully. If there is no flame, repeat the refilling process.
  10. If you experience gas leakage with a hissing sound while refilling the lighter, either you are not holding the lighter and gas can in a straight position or the stem of the gas can is not suitable for the lighter. In this case you need to use an adaptor which is usually supplied with the gas can.
  11. Premium butane is required to ensure optimum performance of your lighter. Lighters require the cleanest butane available at a pressure of 45 psi. Recommended using Premium Triple Refined Butane Gas that are packaged in 10-13 oz. cans with a metal fill tip nozzle. Non-premium butane with plastic fill tip nozzles are not recommended as they may cause inconsistent ignition and performance. Impurity of the gas can cause clogging of the burner valve or malfunctioning.
    WARNING: PLEASE, ALWAYS KEEP YOUR LIGHTER AWAY FROM THE REACH OF CHILDREN. USE COMMON SENSE IN HANDLING YOUR LIGHTER.
    Troubleshooting: If you are having problems with your lighter, make sure that:
    You are holding the lighter upside down while refilling. If you did not hold the lighter upside down, there will be air inside the butane tank. You will need to let the air out and try refilling again.
    The flame height is properly adjusted.
    You are not using cheap or incorrect fuel.
    There is no dirt or debris in the lighter. Try blowing forcefully into the top part of the unlit lighter.
Dec 15, 2008 | HHP 12V Cigarette Lighter Adapter (for the...
Blazer GB2001 Self-Igniting Butane Micro-Torch Logo
564 people viewed this question
Top Blazer Science & Laboratory Experts
William McMath
ray gallant
Are you a Blazer Science and Laboratory Expert? Answer questions, earn points and help others
