Question about Texas Instruments TI-83 Plus Calculator
Tcdf What goes after tcdf
WHAT IF I PUT GAS WHERE THE OIL GOES
if you mean where the chain oil lube goes then you could have a fire if any sparks occure ! If its where a seperate 2stroke oil feed should be then you will not lubricate the engine internals and sieze the engine ! Just drain out and fill with oil , 2stroke will need to be bled on the side of oil pump !
Jul 05, 2014 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
There are several applications missing on my ti-84. I don't have tcdf, chi squared cdf, or chi squared GOF test. How can I get these on my calculator?
Those functions are in the DISTR menu, accessible by pressing 2ND [DISTR].
If you need any of them, you can download apps from
http://education.ti.com/educationportal/sites/US/productDetail/us_ti84p.html?bid=7
Apr 07, 2011 | Texas Instruments TI-84 Plus Calculator
Trying to hook up cable to a raytheon r10 radar scanner.Needs wiring diagram to show where each wire goes.
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Apr 19, 2009 | GPS
Firing problems
Facing engine from the front of the car.
No. 1 goes to top left
no.2 goes to bottom right
no. 3 goes to top right
no 4 goes to bottom left
Apr 15, 2009 | Ford Escort Cars & Trucks
Fiering order on coil pack p38 40.l
As you look at the engine - Spark plugs first......on the left side of engine.......front to back.......2, 4, 6, 8 (even right),....2 goes to the left coil...top left.....4 goes to the right coil....top left......6 goes to the right coil...bottom left....8 goes to the left coil....bottom left....NOW....right side......front to back......1, 3, 5, 7 (odd left).....one goes to right coil....bottom right.....three goes to left coil....top right......five goes to left coil....bottom right....and seven goes to right coil....top right....hope it helps
Jan 28, 2009 | 1999 Land Rover Range Rover
I need a diagram for a serpentine belt, for a 2000 ford taurus se
Starting at the crankshaft pulley, and going clockwise, the belt leaves the crank pulley,
Goes around the tensioner,
Goes around the water pump
Goes around the alternator
Goes around the upper idler
Goes around the Power Steering pump
Goes around the air conditioner pulley
then goes back to the Crank pulley
Sep 06, 2008 | 2000 Ford Taurus
Texas Instruments TI-83 Plus Calculator Logo
15 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
