Question about Maytag Washing Machines
Defy daw 365
My defy daw 365 the wash light and end light is on but it is not doing anything i have to switch off to open the door
4 Suggested Answers
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
go to macspares.co.za
They have couple of diagrams
Posted on Mar 29, 2010
  • 24 Answers
SOURCE: When I start the machine
remove hoses going to the back of the machine. There should be little screen filters inside where the hose goes. Remove them and clean, replace the hoses... This should fix the problem.
Posted on Aug 13, 2010
  • 6277 Answers
SOURCE: defy daw 366 washing machine
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 03, 2011
My Defy DAW 365 washing machine goes through the whole washing cycle but it just won't spin. It does drain between the washing cycles.
If the poly-vee drive belt in your washing machine has snapped, the motor will no longer be able to turn the drum. The drive belt is an important component of any washing machine as it drives the motion of the unit where the clothes are washed and spun. If your washing machine is making a loud noise or no longer spins, then the belt is probably worn or damaged.
Oct 23, 2015 | Washing Machines
DEFY DEW365 WILL NOT START DOOR LIGHT STAYS ON AND PRE-WASH LIGHT FLASHES
Your machine thinks door is open probably bad switch indicating
open door replace switch
Aug 18, 2015 | Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
When I start the machine to do wash using any mode, there's no water coming into the drum but it keps on spinning. Defy DAW 366
Aug 13, 2010 | Washing Machines
Aug 13, 2008 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
