Question about Kenmore Washing Machines
KENMORE MODEL #11044921 301
ERROR 06
Wash machine reads f 06
What is the model number?Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its like a faulty CCU.
Nov 27, 2012 | Kenmore Washing Machines
Kenmore HE3
Terry, here's the fault definition and the checks/repairs for it... F/06; Drive Motor Tachometer Error "The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes." Check/Repair; * Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) * Check the Drive Motor * Check the MCU * Check the Wire Harness If you can next time, please provide the entire model number in your post so we can help a bit more. Kenmore doesn't actually manufacture anything, they purchase their units from manufacturers and slap the Kenmore label on them. The model number is located just inside the door on the frame of the unit.
Oct 03, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I am looking for the drum size for a kenmore dryer model number 66702692
29 inch dryer... Drum PN 695587
If you need parts here is the link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11066702692/0582/0151200?searchedModel=66702692&blt=06
Belt is 5 ribs and 94 inches long. PN 660996
Substitution: PN 341241
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Kenmore Dryers
My Kenmore Elite Calypso Model #110.24086200 SN #CR3808384 is not completing it's cycle and error code (06) shows up. What does code (06) mean?
Error codes start on page 46 and detailed instrustions to run diagnostics start on page 47.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Mar 20, 2011 | Kenmore Washing Machines
Washer shuts off and flashes code 06
ive had this error code before its a drive motor tachometer error it is the same error code in both kenmore and whirlpool when you order to replace the piece it comes in as enitre harness fromthe motor all the way up the side of the machine to the board
Apr 30, 2010 | Kenmore 45081 Front Load Washer / Dryer
F and then 06 error/ Kenmore elite HE 3T series 4
well i found the answer on browsing through fixya. the following would assist you with the needy.Hoe it is helpful.Pay back with your comments if the problem is solved.
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis HE F1 Error
Im sorry to tell you but you have a bad control board. This was a faulty board from the factory. There is a class action lawsuit agianst whirlpool (whirlpool made the oasis). Try calling to get whirlpool to fix it. Maybe try joining the lawsuit. They have remanufactured the part so the new one wont do that again. Its a great machine when it works right.
Nov 18, 2008 | Kenmore Oasis HE 27087
Model 110.45962.400 code comes up f 06
The following link explains the "F06" error code on a Kenmore Elite:
In a nutshell, the error is an indication of a Motor Speed problem. This means there is a communications problem between the Central Control Unit (CCU) and the Drive Motor or Motor Control Unit (MCU).
However, before assuming there is a problem, unplug the washer for at least 30 minutes. In some cases the washer can experience momentary computer glitches. The 30 minute interval is necessary to reset the computer. Sometimes this is all that is required to clear some error codes.
If the error code returns following a reset, follow the advice given in the link to determine the fault.
I hope you find this information helpful. If you require additional assistance, please let me know.
Sep 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
