Onida29oxygen ic tda9376/n3/a/1733 - Televison & Video
-A22, IC-A22E wiring digarm
Search at google for service manual of IC-A22E
Oct 22, 2013 | Icom CM-166 IC-A3, IC-A3E, IC-A22, IC-A22E...
Cdx gt630u
hi rohan, which ic is it?? sound ic? power supply ic? control ic? preamp ic? tuner ic? plz send more specific details? plz send picture of the ic placed in circuit?
Sep 07, 2013 | Car Audio & Video
Nokia 3110 fall in to watter and dead
1..remove this coil mark in (1)...if u want to check is pf is short,..... 2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 4..remove this coil mark in (4)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery.... 5..remove this coil mark in (5)..if u want to check the light ic is short.... 6..also check the memory card driver ic n3200 it also got +b it can be check by only removing this ic..... 7..at end remove retu and tahvo ic .. all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .3500short.jpg
Dec 06, 2011 | Nokia 3110 Cellular Phone
IN TV i have not get a picture on av mode mean av is not switching in this tv IC 9380PS as microproccessor IC & 24c16 as memory IC
look to the IC near the AV jack there is a AV switch IC. try to replace it. but some tv use a large IC jungle which is the AV sw. is also inside that large IC.So study carefully if your tv has a separate AV sw. IC..
Jun 04, 2009 | Televison & Video
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Problem in one IC
i want graphics driver
Feb 08, 2008 | Intel D845GVSR Motherboard
ICOM W2a Won't power up, after full charge with two different batteries
There's a comment on eham.net about charging the internal battery first.
Maybe this will help you.
http://www.eham.net/forums/ModsAndRepairs/1961
Jan 10, 2008 | ICOM Informatique BP-85S,...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
