Silver crown xgb-70968el
On the display error E31 i dont no what that means
2 Suggested Answers
huuum
  • 750 Answers
SOURCE: E31
Hello Smithysarah,
Welcome to fuixya,
You said, HI MINE READS ERROR E31 WHAT DOES THIS MEAN?
E30 or E31= Motor Drive Problem -
Run the programme again,
if problem persists call for
a Service Engineer.
I will tell you a secret.
Try unplugging the washer for 5 minutes and then we will see if this has reset the system!
like rebooting your computer.Some times it is only a glitch and no mechanical problems are there!
If so you saved a service call.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank you.
Waiting for your results!
Posted on Oct 17, 2008
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
E31 error code on electrolux washing machine
Good Afternoon Friend,
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
Jun 08, 2014 | Electrolux EW1000i Front Load Washer
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
White westinghouse dryer
Hello Mizar - Thank you for allowing me to assist you. If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 29, 2013 | Electrolux Dryers
E31
Hello Stephanie - If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 02, 2013 | Frigidaire Affinity ATF7000E Front Load...
ERROR CODE E31
Hi and Welcome to Fixya!
E31 simply means - Waste Toner Reservoir Overflow Problem (when the total number of copies is more than 100K sheets). After E31 is displayed, 1000 sheets may be copied before shutdown.
Hope this helps!
Takasashi
Jul 13, 2011 | Kyocera Copystar CS-1620 Black and White...
What do these codes mean E31-E41-E74-F31? can you help?
E31 = Shorted MAP cicuit sensor
E41 = Cam sensor circuit problem
E74 = Intermittent MAT
F31 = Display panels to BCM problem
This is to say if the vehicle is a 1991 Cadillac Deville
Then the Trouble Codes are as I listed above.
For future reference, the F is for BCM codes.
When entering the on screen diagnostics the display starts with one E for the PCM history, then E.E. for current. Same sequence follows for BCM codes starting with one F for history and F.F. for current ones
Mar 15, 2011 | 1991 Cadillac DeVille
E31 error message on screen of pinseeker 1500 bushnell
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. "lob" means low battery condition. In these rangefinders "lob" will show up with a new non-alkaline battery installed. Non-alkaline batteries just don't generate enough current for the laser to operate properly. Reprogramming costs about 20 bucks, if it needs an alignment (won't hit a flag or target at 200+ yards >50 bucks<) Oily looking spots in the display are from not using the eyepiece cap and direct sunlight damages the LCD. (15bucks) The address for repair is:
Bushnell Repair Center
8500 Marshall Drive
Lenexa, KS 66214
800.423.3537
Send a problem statement, your phone number, and $10 for return shipping.
Good Luck to you!!!!!
Mr Tech Geek
don't forget to vote/rate me....
Jul 03, 2009 | Bushnell Optics
E31
Hello Smithysarah,
Welcome to fuixya,
a Service Engineer.
Huuum
Thank you.
Sep 30, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
