Question about Scosche Industries Scosche tuneIN Universal FM Transmitter
Problems scosche fm transmitter
Use it to plug into computer to watch PC on television - plugged into my computer but frequency is stuck on 88 and 107 (as opposed to it usually being on 88 and 3). Button will not change frequency.
Why does my scosche corded fm transmitter say loading and does nothing else?
A component on the mother board may have defaulted. May need replaced. Or a wire or cable is disconnected. Try rebooting the system.
Mar 11, 2016 | SCOSCHE Corded FM Transmitter for...
Scosche FM Transmitter won't change stations and is just lit on 107 and won't change . What's the problem?
Bad transmitter, open the back side after in plugging it and check the brass contacts for continuity!
Nov 11, 2014 | Audio Players & Recorders
How do i use scosche fm transmitter
You plug your mp3 player into it and then it broadcasts the audio to any FM radio that you are near. so it is a wireless connection like bluetooth for sending your music to a car radio without wires.
May 15, 2014 | Scosche Industries Scosche Fm Transmitter...
Scosche FMTD3 transmitter wont turn on anymore
Same problem with mine a couple months after purchase.
Jan 09, 2013 | Scosche Industries Scosche Tuneit Goose...
Scosche fm transmitter FMTD8 not playing mp3 files on Flash drive
I bought the fmtd8 scosche transmitter. If you're like me ,you tried to play music from you're cell phone first. That worked just fine. Then I made an sd card with a few hundred songs on it. P.S. I left the audio cable plugged in the the transmitter. The sd card with mp3. songs would not play for anything. After 2 days of trying,I finally decided to unplug the audio cable.. Voila!!!!! Instant sound.
Dec 28, 2012 | Car Audio & Video
Hi is it possibleto play the audio through the car radio? If so, how? Many thanks
if your talking about playing an mp3 through your car radio, just go to your local walmart and buy a scosche FM transmitter in the automotive section, only $12 and take 2 AAA batteries
hope this helped
http://www.walmart.com/ip/Scosche-FM-Transmitter/14666784
Nov 16, 2010 | Car Audio & Video
I installed the FM transmitter module which came with my samsung LCD TV model LA40C530F 1R. I tried accessing the FM transmitter menu in order to turn the transmitter On and to set the frequency but that...
1. Press the menu button(green)
2. down arrow once - (a picture of a speaker should appear with sound written vertically next to it)
3. Right arrow once (selects the sound menu)
4. Down arrow till you see FM transmitter (down arrow 4 times on my TV. If you don't see the FM transmitter option in the menu then upgrade your TV to the latest software (details at the end of this help file)
5. Right arrow to get into the FM transmitter menu
6. select the "FM transmitter: off" line and turn it on (FM transmitter : on)
7. Change the frequency to to one that is not used by a radio station or has interference noise (get a radio and tune it till you hear the choosh sound with no beeping or clicking from lightning - then set the tv fm transmitter to that frequency using the up and down arrow keys and enter.
8. You should here your tv sound comming through the radio even if the tv sound is off.
If you need to upgrade your tv software then:
1. format a usb stick
2. download firmware.exe from"
http://www.samsung.com/za/consumer/tv-audio-video/television/lcd-tv/LA32C530F1RXXA/index.idx?pagetype=prd_detail&tab=support
3. click on firmware
4. click on "Upgrade File(USB type)" and download it to your usb stick
5. when the download is complete double click on the file and extract it to the usb stick.
6. eject the usb stick.
7. plug it into your TV and slelect software upgrade when prompted - I didn't loose any settings even though it warns you that you will (samsung are just covering themselves)
Sep 03, 2010 | Televison & Video
IS THERE A WAY I CAN PLAY IT IN MY CAR IN THE RADIO
Yes, You will need to purchase a device called an FM transmitter, it plugs into the headphone jack and transmits the sound to your FM radio. The transmitter will have station settings, you just find a radio frequency that does not have a station in your area, set the transmitter to that and tune your radio to the same frequency. You can get the transmitters from Walmart electronics dept, Target, Sears, Amazon.com, Radio Shack and most other electronics retailers. The transmitters run about $12-20 and can be battery powered or plug into your car power outlet. Go to google.com and do a search for "MP3 FM transmitter" and you will see what they look like.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | iRiver E100 Digital Media Player
How do you install this thing
Hello cmiller23606,
It installs in a Toyota Yaris or any other vehicle exactly the same way. The device is an FM modulator and has no vehicle specific wiring. You do need a 12V source from the vehicle and a ground connection as well as access to the radio antenna jack.
Connect power and ground to the 40" wire with the inline switch. Be sure to observe polarity. Piggyback the modulator directly onto your in dash receiver by removing the antenna lead from the receiver and plugging it into the FMMOD01. Then run the 21" cable from the modulator to the now vacant receiver antenna jack. Mount it with screws, double sided tape, plastic wire ties, velcro, or permanent glue. Using the side-mounted slide switch, select an FM frequency of either 87.9 or 88.3, plug a source (CD player, minidisc, videocassette or DVD player, iPod, MP3 player, or any other source with a minijack or headphone output).
Tune your in dash receiver to the selected FM frequency and you're ready to go.
Hope this helps.
Aug 08, 2009 | Scosche Industries Scosche Audio...
Using my car speakers with my Garmin Nuvi 350
No, unfortunately ther is no way to get the unit to use your car speakers. To do this, the unit would have to have an FM transmitter or be able to connect to one. It does not have this capability. Sorry.
May 20, 2008 | Garmin nuvi 350 GPS Receiver
Scosche Industries Scosche tuneIN Universal FM Transmitter Logo
109 people viewed this question
Top Scosche Industries Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Scosche Industries Audio Player and Recorder Expert? Answer questions, earn points and help others
