Question about Altec Lansing ADA995 Speaker
Volume control how adjust volume on ada995
Altec Lansing ADA995 Speakers. Can these speakers be used with a home audio system (Technics) or a television (Phillips). JRS Denmark jrschou@live.dk
Hi there , not long ago I was having issues with my VS 2420
I wasn't getting any replies to my queries when requesting help through the web site then someone forwarded me the following
Contact: nicky.cook@alteclansing.com , seems to be manager customer care I got a reply within 24 hrs and a new one was shipped to my UK address within 58 , awesome service ! :D
Feb 24, 2011 | Altec Lansing ADA995 Speaker
Sound is very low
What are you using for the sound source? That could be where the volume is being lost.
Here is a troubeshooting guide.
http://support.dell.com/support/edocs/acc/ada995/trouble.htm
Mar 13, 2010 | Altec Lansing ADA995 Speaker
I have an ada995 and want to run it on a dell inspiron 15
go to http://support.dell.com/support/edocs/acc/ada995/usage.htm
u will find everything u need to know about using ada on ur dell
Mar 12, 2010 | Altec Lansing ADA995 Speaker
Altec Lansing ADA995 Speaker system partial speaker play
Drivers and support softwares for Dell Dimension 9100 are still very much available to Dell's website (here). Download the audio driver for your StaCruz Audio card.
Hope this helps. Please don't forget to rate.
Nov 07, 2009 | Altec Lansing ADA995 Speaker
Connecting an Altec Lansing ADA995 subwoofer system to a stereo
I have this exact Altec Lansing speaker system and I'm currently just using it with my Dell computer. But, I know you don't have to install these speakers to any high powered receiver for good sound quality. The subwoofer has two separate 200 watt RMS combined amplifiers built in for it's single knob controlled dual 6.5" bass drivers and 2-way magnetically shielded satellites, which are amplified together by any source that has an analog or digital volume control. The speakers act as a preamp receiver to any volume or frequency tone level controlled audio source. These input sources can also equalize the speakers receiving input signal for bass, treble or mid-range adjustments. You only need to obtain the proper adapter to hook up all the speakers to your desired component or device. Besides a computer, for example a TV with a variable audio out function or a mp3 player will work. The adapter that i am referring to is similar to what is included with certain 5.1 Logitech brand computer and multimedia speakers specifying gaming console and TV connecting. It has all three color coded 1/8" connector inputs on one end and RCA jack outputs on the other. This can be purchased more easily online then offline at stores such as Ebay for a fairly inexpensive price. However this adapter will not decode true 5.1 surround, but instead give a 5 channel stereo effect. I guess if one was looking for an inexpensive alternative solution to purchasing traditional high end home entertainment audio equipment, the ADA 995s are one of few computer speaker models in my book that can do a decent job.
Jun 19, 2009 | Altec Lansing ADA995 Speaker
Hooking 5.1 computer speakers to a Samsung Plasma
Computer speakers are powered, they have their own amps inside the speaker cabinet.
To get these to work on a TV you need to plug them into a headphone out jack.
The external speaker terminals produce too hot a signal for powered computer speakers. The amp in the speakers may have already been damaged.
May 04, 2009 | Altec Lansing ADA995 Speaker
Is it possible 2 connect altec ada995 to sony KDF 50E300 52 in TV
I was in the same situation you are in when I got my new computer. Provantage sells this little adapter: http://www.provantage.com/logitech-970150-0403~7LGTC96V.htm
The only problem is, since the genius who made this model didn't put an external volume control on the speakers, there is no way to control the volume. they operate at full blast. which is, as you know, heart stopping. to combat this problem i used another adapter I found at radio shack(http://www.radioshack.com/product/index.jsp?productId=2103710) and plug it into my tv's headphone jack.
hope this helps. If you find another way to control the volume PLEASE let me know.
Mar 22, 2009 | Altec Lansing ADA995 Speaker
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Altec Lansing ADA995 Speaker Logo
44 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
