Question about Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
2 year old indesit front laoder washing machine is showing error code f002.can anyone help please!
  • 5 more comments
  • davymac Aug 16, 2007
    have changed the brushes.the motor is trying unsuccessfully to spin
    motor spins but it is interrmittant
    drum is moving freely
    unfortunately the motor has blown!!! any ideas why?
  • Anonymous Mar 13, 2014
    how to start the indesit win 102 washing machine
  • Anonymous Mar 14, 2014
    SHOWING f-13 error code machine won,t wash
  • Anonymous Apr 01, 2014
    HOW DO YOU ADJUST REAR LEGS
  • 641 Answers
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
  • Dov Dror Aug 16, 2007
    Try to remove the belt and see whether the motor will spins ?
    In case it will spins, check machine's tub for free movment.
    Let us know with your results.
    Replace the capacitor.
SOURCE:
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Indesit w127 error code f-08
Error F08 is indicating that the heater relay is stuck or cannot be activated or the contact has welded in the relay.
The only thing u can do yourself, is to check that the heater is o/k, if u can determine that it is , then u have no option other thancalling an engineer.out.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Nov 13, 2007 | Indesit W 123 Front Load Washer
Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Aug 26, 2007 | Indesit W 123 Front Load Washer
Indesit w123 washing machine
Suggestion: The pipe behind your machine has to have a certain height (the machine drain pipe); it does not go directly into the drain at floor level. Check this out.
May 22, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
2,078 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
