Question about Globe Union Lavatory Faucet
Danze shower diverter a603819 - Globe Union Lavatory Faucet
Why is water coming from shower head and faucet at same time?
sounds like you need a new tub spout with diverter...thats your problem...unscrew spout and go to lowes and match up with new one...use pipe dope on threads and reinstall new one...good luck
May 30, 2012 | Danze & Single Handle Tub And Shower...
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
My shower/tub diverter lever is loose. How do I tighten it?
should have allen screw on bottom of spout...or just turn clockwise mite have an adapter but more likely to have allen screw to tighten spout..
Nov 22, 2010 | Danze & Plymouth& Single Handle Tub &...
The water comes out of both the shower head and the tab simultaneously. If the knob controlling the water flow is turned to the side that control the water to shower head then about 75% of the water flows...
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Jun 02, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze sonora roman tub personal shower stopped spraying, no kink in hose, no plug in sprayer
I had the same problem and just now fixed it.  Remove the faucet head - the tub filler - and pull out the diverter tube insert.  It's the valve at the bottom that's sticking - probably because of calcium or mineral deposits.  I washed mine with white vinegar and pushed a wooden spoon handle down the tub to unstick the valve, scrubbed it with vinegar and a toothbrush and re-installed.  Works perfectly now.
Jun 27, 2009 | Danze D303754CSN Sonora Roman Tub Faucet...
Getting into Danze Roman faucet to unscrew it
I don't want to pay for anything.  I didn't realize there was a fee attached until I got to the last part so I just shut my computer down without selecting a payment and still you contacted me.  No thanks!  Remove me.
Jun 22, 2009 | Danze Home
Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Apr 06, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Globe Union Lavatory Faucet Logo
98 people viewed this question
Top Globe Union Home Experts
john h
Tom Chichester
Are you a Globe Union Home Expert? Answer questions, earn points and help others
