Question about Pacific Image PrimeFilm Office Equipment & Supplies
CyberViewX does not initialize scanner
After long minutes waiting for the scanner to initialize, CyberViewX returns a message saying that it is unable to communicate with the device.
5 Suggested Answers
gcsltd
  • 239 Answers
SOURCE: Error while communicating with scanner message
Smile...well this is due to a default setting in windows which u need to change.
1. leave the device plugged to the USB & power it
2. Go to device manager \ expand (+) universal serial bus controllers
3. Right-click \ properties \ usb root hub \Power management tab \ uncheck box (allow the computer to switch off the device)
Restart! Don't forget to vote me dear!
Posted on Feb 07, 2010
Rain041304
  • 63 Answers
SOURCE: On the CanoScan 5000 I try to open the Scanner and
Try using other application aside from the canoscan. Try to use Paint, you just click on File then from scanner. If it doesn't work, check the scanner itself, try to plug it in on another power outlet, if you are using a power surge try to unplug it and directly plug it in to the wall. You should notice the light on the scanner. If it is not litting up, you need to have the scanner serviced due to defective bulb
Posted on Sep 05, 2009
SOURCE: IScanner not communicating w/ PC
If your scanner is like mine the software comes defaulted to look for the OVT Scanner. Go into properties and change the scanner default to Cyberview CS Memor-ease.
Posted on Jan 15, 2010
SOURCE: Error message says: Scanner is locked.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Posted on Mar 05, 2010
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
I have canon ir3750. When I switch on the machine it goes to the start screen , The screen displays wait message, for about 3 minutes and than nothing happens and then the error code message comes up...
This is an error in the communication with the scanner. Check or reseat the connectors from the scanner , check to see if the scanner even moves during initialization ( power supply for it may be bad ), check/replace reader controller, scanner board, or main controller of copier. I've not seen this error before. Good luck.
Jun 23, 2011 | Canon imageRUNNER 5000 Copier
Looking remove all stored channels from scanner and start over.
Initializing the scanner will erase all programmed information and return your scanner to its original factory settings. To initialize your scanner:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" appears on the display.
- Press 0 (zero) while the above message is displayed.
- Press 1.
- Press ENT. "Initializing please stand by" appears on the display.
DO NOT power the scanner OFF until the initializing process is complete and the display shows "M000 Bank0 Ch00"
Bill B.
Listening in professionally since the 60's
Mar 22, 2011 | Radio Shack Pro-2055 Base Scanner
Will not print. says code 2200 just replaced black carterage
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved. 2
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3. 3
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black / photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved. 4
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black / photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black / photo cartridge. If the printer fails again, continue toContacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved. the 2200 error is a scanner error means the scanner motor failed to initialize. lexmark recommends that you unplug the unit remove the power supply wait a couple of minute reinstall the p/s and power the unit back up. step to is repeat step one but us the belt to move the scanner carriage to the middle and power it up.
on top of this i would inspect the guide bars for dirt build up and clean them if need be. one thing to consider the ccd knows that it has reached home by the reflecting of the light to the carriage home photo cell within the scanner itself. this light is reeflected back off of the mirrors inside of the ccd. dust on these mirrirs will prevent the photo cell from nowing where home is. these can be cleaned with q-tips
plz rate the solution
Nov 02, 2010 | Lexmark X7170 All-In-One InkJet Printer
Samsung s5233 unable to open message box as it says initializing
Apr 16, 2010 | Samsung Star GT-S5233 Cell Phone
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
I scanned successfully. Next attempt says "Unable to initialize the scanner". I can't get past this (Brother 8820D)
the program you were scanning to probably didn't release the scanner. first thing to try is turn the scanner off for a minute or so and then back on.
Aug 13, 2009 | Brother MFC 8820D All-In-One Laser Printer
Minolta Dimage multi pro
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
169 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Willem.
Willem.
Greg Cann
Greg Cann
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
