Question about Husqvarna 223L
Why won't my Husqvrana 223L trimmer crank?
I've cleaned carb and filters! I also changed the plug!
  • Plink-plonk
    Plink-plonk May 09, 2013
    Does it have a spark when pulled over.? Is fuel getting into the cylinder and wetting the plug.? Does it have good compression.?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Electrolux products are junk, should have bought a stihl.
Posted on Jul 04, 2013
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded.
second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
May 30, 2013 | Husqvarna 223L
Husqvarna Problems
Have you changed the fuel tank vent.? Could possibly be a vaccum being created in the fuel tank, starving the carb of fuel.
May 21, 2013 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Have two string trimmers, both hard to start. shindawa homelite 62061 & toro TB21EC. H/L does great job when it starts. Toro won't come up to speed. Have cleaned carbs in both and checked plug
When you say it will not rev up to full speed, that sounds to me like a blockage either in the spak arrester in the muffler outlet, or the exhaust port is blocked, or the muffler itself is blocked.
May 11, 2012 | Toro Garden
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
I have a 2 cycle Troy-Bilt line trimmer. I've had
Sometimes, unfortunately, the chemicals and solvents used in a "dip" and/or cleaning solution are too harsh. They tend to "swell" the very sensitive check valves inside the carb. The idle fuel circuit has one, the high speed main nozzle has one, and there are one or two inside the primer pase assembly on top of the carb. You state that it won't idle, but does it run otherwise. If it does, some carb adjustments may be required on the L and H screws to get it to idle.
I have a Toro 4 cycle gas trimmer that won't stay running. Starts, then sputters, then dies. I've changed the oil, drained fuel & put in new fuel.
check to make sure the air filter and the fuel screen are clean, the screen is the little white plastic piece on the end of the hose in the tank. if it is still sputtering try cleaning the bell out on the carb. it is the little metal cylinder on the bottom of the carb where it holds the fuel until it evaporates into the engine if it gets clogged the engine will not run properly.
Jun 30, 2011 | Garden
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
I have a 25 cc Craftsman weedeater. Using fresh 40:1 gas. I've replaced the fuel lines, cleaned in tank filter, cleaned and rebuilt carb and getting spark, but it still won't start. Also cleaned...
the other possibilities you have is a bad crank seal, or a flywheel came loose and its out of time, will it fire on carb cleaner sprayed in the carb, If it runs for seconds and , then I would say it's not getting fuel, If it only farts once or twice then I would check crank seals cause if they are leaking then your crankcase cannot draw vacumn which in turn causes fuel pump in carb to draw fuel, If you have to check flywheel pull it apart and take flywheel nut off and pull flywheel off and inspect the key that is built into flywheel to see if it is sheared off or messed up, also while checking muffler check for the opening that the mud dobbers havent put mud in muffler pipe, good luck
May 15, 2011 | Craftsman 25cc Gas Line Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Husqvarna 223L Logo
236 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
