Question about Garden
Workforce 163cc ohv repair
Suddenly having trouble starting the engine. When I get it going, it will rev/idle, rev/idle, rev/idle and then die. Okay on fuel and oil. Air filter looks okay. Not a lot of hours on it. Thanks, Jim
  • 35 Answers
SOURCE: Rough Idle 2000 ford Taurus OHV
This could be a bad a/c compressor or compressor pulley bearing.Try removing the serpentine belt and turning the compressor by itself.The bearing should turn very easily,and the compressor itself should turn.If it is vety hard to turn,it is bad.
Posted on Sep 25, 2008
  • 1388 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
  • 234 Answers
SOURCE: the washer will run about 2 min. then die. i have
It is possible that the oil pressure switch is not functioning properly or you have a lighter oil in the machine than is recommended.
Post a comment if you need more assistance.
Posted on Apr 27, 2009
polarcycle
  • 1392 Answers
SOURCE: Idles okay, runs rough when gas applied
Either a bad MAP sensor, or TPS. What is the code for the check engine light? This will most likely tell you what it is.
Posted on May 27, 2009
  • 179 Answers
SOURCE: Mitsubishi Montero Sport 2002 Idle problem
the engine compensates for the load try turning up the idle screw also check the ignition system you might just need new wires and or cap rotor or your coil is bad also plugs
Posted on May 31, 2009
I have a 2007 Honda Dylan 125. It was working fine then all of a sudden wouldn't rev up. It starts and idles but as you twist the throttle the engine dies.
Check throttle cable. It may be broke inside the casing. If that's okay it could be a stuck carb float or plugged jets. I hope this helps there are a lot of possibilities.
Feb 02, 2015 | Honda Motorcycles
Engine dies
ignition module possibly or pick up coil
Nov 06, 2012 | Cars & Trucks
Idles then revs
Fuel problem or leaking air into engine.
Mar 12, 2017 | Motorcycles
My car idles at 2k rpm as soon as the check engine light goes off
Most likely airflow meter giving trouble. Remove it and try cleaning it you will get spray for this in an auto factor's or an electrical repair shop. Cleaning may not fix it as it may just be worn out and will need to be replaced. A genuine V.W. one is expencive but enquire at your auto factors they will be able to get you one at about half the price. Hope this helps. Cheers
Sep 10, 2009 | 1995 Volkswagen Golf
Why does my 2002 jeep liberty die when i rev the engine?
its time to replace the idle control valve.
Feb 16, 2009 | 2002 Jeep Liberty
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
