Question about Whirlpool Refrigerators
Whirlpool Model Number mf12269vem
How do I clean under the fridge? The rubber stoppers do not budge for me.
5 Suggested Answers
  • 145 Answers
SOURCE: WHIRLPOOL FRIDGE Model #GD5SHAXQ00 21.9 cubes
Sounds like the compressor relay may be out. I have replaced a few of these compressers but it is almost always the relay. Don't let anyone put a 3 in 1 relay kit on it. That will burnout the compressor for sure.
Posted on May 15, 2008
  • 1214 Answers
SOURCE: can't clean coils under fridge
Carefully. It can be done.
Get an old kitchen towel and a yard stick. Pull the towel over the end of the yardstick, and carefully slide the end of the towel between the coils, using the yardstick. Carefully sweep side to side, while at the same time, having the vacuum cleaner nozzle in the vicinity to capture loose fugitive dust. Carefully pull the towel out, and vacuum the dust off the rag.
Do this from front and back, being careful to not damage the tubing. The little wires are OK to bend some, just don't put to much force on the refrigerant tubing. Take your time, and you'll get the coil clean.
Posted on Dec 18, 2009
  • 93 Answers
SOURCE: Have a Whirlpool Fridge model
use new newspaper crumpled up for a few days or charocal briquets also works good. u might check in freeze take back plate off might be some food in there.. ok
Posted on Feb 12, 2011
imufo2
  • 3773 Answers
SOURCE: there is a lot of
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 21, 2011
I have a Whirlpool fridge that needs a new water filter. Twice now, when I remove the filter to change it, water gushes out even though the ice maker is OFF. I quickly turn off the water line and mop
The Whirlpool fridge requires a water supply connection to a cold water line. Before you connect the water supply to the water line on the fridge, make certain the unit is unplugged from the wall. Press the button and drop down the cover. Then twist to release the old filter and twist the new one into the filter head. Run about 2 gallons of water through dispenser to remove any air from the lines. Liquid EPDM Rubber Roof Coatings for Roof Leaks Repair EPDMCoatings
Jan 29, 2014 | Whirlpool Refrigerators
Need to remove dead battery but it won't budge
their is a hold down scerew on bottom of batter with a rubber stopper that you must take off to remove it
Aug 01, 2011 | 2001 Mercedes-Benz C-Class
Crime stopper remote start, panic activates with remote start
try and reprogram the remote buy looking under your dash and getting the model number of the unit then go to www.crimestopper.com and choosing the support tab then choosing manuals and manuals again using the model number from under the dash find yours you can also contact tech support at 800.998.6880 ext 210
Oct 27, 2009 | 4-Button Remote Start/Keyless Entry with...
Need part number for door latch for an LG LRFD25850ST
A fridge does not have a door latch, the door is held closed by gasket and a door stopper.
If you are looking for door stopper, here the part:
Stopper, door part1. 243A on diagram.Number:4620JJ3006CSubstitution:4620JJ3006D
Stopper, door Part2 - 243B Number:4620JJ2009A
Here the diagram find the part and check part list below:
You find the part list and part here: DOOR PARTS
Sep 19, 2009 | LG LRFD25850 French Door Refrigerator
Whirlpool frbb36af20/2 fridge freezer manual anybody have a manual on download thanks ian
If your model number corrected I could find the user manual. But if you look inside and down along the bottom frame of the door and near the door rubber seal you may be able to find the correct model number. Just click on the link below and enter your model number. Thanks, Sea Breeze
Sep 18, 2009 | Refrigerators
Bad smell in tray at rear of fridge
maybe you could use a wet/dry shop vac to clean it out
Jul 30, 2009 | Refrigerators
Slow water drain from Royal whirlpool tub. How to
under the decorative knob there is a screw,this is what holds the stopper in place.if not it should just unscrew.
Jul 29, 2009 | Home
Extra part
GVW9959K
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GVW9959K
click on your model number. In the new window click on the diagrams in the left-hand side. You will have to examine them to try and find the rubber part.
Mar 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
