Question about Waterway 2 Hp 3450rpm 115 Volts Above Ground Pool Pump Brand with Large Debris Basket & Power Cord # Ph1200 6
What is the part number of the reset button on the motor of the waterway pump?
    Top Expert:
  • Waterway Master
  • 4,290 Answers
No reset if blows breaker need new pump
Posted on May 01, 2016
2 Suggested Answers
  • 2006 Answers
SOURCE: I have a PF-50-2N22C Waterway
http://www.spapumpsandmore.com/PhotoDetails.asp?ShowDesc=N&PhotoNumber=4&ProductCode=WATERWAY37220211D from the schematic on the motor, it doesn't look like there is a reset on that motor.
Posted on Jun 26, 2011
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Can I replace my waterway wet end pump model
its not adviseable to go down in Hp (4 to2 )of a pump motor all your jets are not goiing to proform correctly
Aug 26, 2014 | Pool & Spa
High pitched noise on waterway pool pump is it a seal?
no its the motor bearings need new pump motor
Jul 02, 2014 | Waterway Pool & Spa
What direction does a waterway hot tub motor turn
The only way a motor will run backwards is if the motor gets wired wrong.
all motors turn clockwise.
Rod
US Parts Center
888-521-6183
Jan 03, 2013 | Pool & Spa
Can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Apr 10, 2010 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
1.5 hp waterway champion pool pump issue
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
Jul 28, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
I am replacing a Waterways Pump and Motor 220v with a new Pentair 220 v 2 hp. I need to know how to wire it.
on the motor is a label giving the hp and motor specs. there is also a figure on the label showing the wiring for low voltage and hi voltage.
David
May 03, 2009 | Pentair 3hp Whisperflo Pool Pump In -...
Waterway 2 Hp 3450rpm 115 Volts Above Ground Pool Pump Brand with Large Debris Basket & Power Cord # Ph1200 6 Logo
26 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
