Question about Lexmark MFP-X3470 All-In-One InkJet Printer
"cartridge incorrect" message
I am unable to clear "cartridge incorrect" from my all in one printer after I replaced the ink cartridge. I tried cleaning the cartridge and where you install it, as well as powering it off/on, but nothing helps. Could the cartridge be faulty? I threw out the reciept.
  • Anonymous Mar 30, 2008
    yes i have the same problem whre can i find the solution
Where do you put the cartridge in the lexmark?
Posted on Apr 13, 2008
With reference to solution #1, you need to to get a firmware upgrade file named "CartErr Test.exe". Contact Lexmark.
Posted on Sep 04, 2007
My best guess would be incompatibility between cartridge and printer. I'm in touch with Lexmark regarding the "Cartridge incorrect" problem. They came up with the idea of cleaning cartridge as well as the connection points inside the cartridge holder despite the fact that my X3470 is brand new and never printed out a page! First installed with the start cartridge and later by a replacement cartridge with the part no. 18C0781E. The carton claims compatibility between this cartridge and X3470. The cartridge have benn tested on my other Lexmark Z735 printer without any problems.
Posted on Aug 31, 2007
    Sergeant:
  • 390 Answers
Never throw out any receipts!!! A lesson my dear mum taught me a long time ago. You need to pay attention to what the printer is telling you. Incorrect cartridge error message could mean a clogged printhead, most people think they have cleaned properly but did you do it with proper cleaning solution. Was it a refilled cartridge or new one? Are you certain you did not accidentally touch the gold areas (printer points) as this can put oils and dirt or residue on the cartidge. Gently wipe both heads on cartridge very softly with a non perfumed baby wipe! Yes a baby wipe (people laugh at me until they see their printer go again!!!) Now try printing again. You can get rid of error message only when you fix the problem. If nothing helps, try uninstalling the printer and reinstalling with original operating disc. And yes, the printer cartridges can be faulty. Never dispose of your old receipts until you are virtually replacing the next cartridge. I keep all receipts for all costly items in a clear slip folder, or staple to original barcodes of box they came in. Did you try disconnecting usb cables to printer and reconnecting to reset it.
Posted on Aug 11, 2007
SOURCE:
How do I undo unable to clean 46 message
This error is for the Waste Ink Station.
The Waste Ink Station is full. This requires a full dismantle of the machine to clean out and then a reset process run to clear the waste ink counter.
Sep 09, 2014 | Brother MFC-790CW Multifunction Printer
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Incorrect cartridges message on printer screen c4183. help me
Complete the following steps in the order presented until you resolve the issue. Step one: Remove and inspect the cartridge
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, and then wait until the carriage is idle and silent.
  3. Press down gently on the top of the cartridge to release it.
  1. Figure 2: Removing the tri-color cartridgec00484998.gif
  2. Slide the cartridge out and inspect it.
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 3: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear protective tape has been removed from the nozzle and electrical contact area. Figure 4: Removing the clear protective tapec00211538.gif
  3. Reinstall the cartridge in the product and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step two: Make sure the cartridge is compatible Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, click this link, HP SureSupply . If your language or country does not display next to the globe icon (c01906983.gif ) select your language and location.
  1. If the cartridge is compatible, reinstall it in the printer.
    • Place cartridges marked with a triangle in the left carriage slot.
    • Place cartridges marked with a square or pentagon in the right carriage slot.
    Figure 5: Print cartridges installed correctlyc01091334.jpg Figure 6: Direction to insert the print cartridgesc01091335.jpg
  2. After verifying that your cartridge is compatible, reinstall the cartridge in the product and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step three: Clean the cartridge contacts
  1. Open the printer lid and wait until the carriage stops moving, and then unplug the power cord.
  2. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: If you are removing a tri-color, photo, or gray photo print cartridge, try to clean the contacts quickly enough that the cartridge is not outside of the printer for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside of the printer for too long.
  3. Dip a clean cotton swab in distilled water, and then squeeze it to remove most of the moisture.
  4. Clean the print cartridge contacts. Do not touch the nozzles. Figure 7: Cartridge electrical contactsc00832021.gif
  5. Clean the contacts inside the carriage, inside the printer. c00246272.gif
  6. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
  7. Reinstall the cartridge, plug in the power cord, close the printer cover, and then try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step four: Reset the printer
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
  2. Open the cover of the printer and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message.
  4. Disconnect the power cord from the back of the printer and wait for one minute.
  5. Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try again to print.
If after you have completed these steps you are still unable to resolve the issue, go to the next step. Step five: Replace the cartridge If after you have completed these steps you are still unable to resolve the issue, replace the cartridge. If you do not have a replacement print cartridge, go to the next step. Step six: Print in backup mode If you do not have a replacement print cartridge, you can still print in ink backup mode until the issue is resolved. Remove the problem cartridge and print with the remaining cartridge.
  • If you remove the tri-color cartridge, the printouts will be in grayscale.
  • If after you have completed these steps you are still unable to resolve the issue, service the product.
  • If you remove the black or photo cartridge, the printer will print more slowly and the colors in the printouts may differ.
I hope this solution will helpful for you. Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful. THANKS & Keep Using fixya
Jul 28, 2011 | HP PhotoSmart C4180 All-in-One Color...
"wrong cartridge"- Printer is giving us a "wrong
Hi Sherri
I am having the same problem with my MP780 mine started doing the same thingafter deciding to use Calidad inks the large black ink leaked into the yellowink (stick to canon inks).
What I have done so far with no success -
Replaced the ink cartridges with new ones supplied by Calidad, still the sameproblem.
Removed and cleaned the print heads manually and to my surprize after soakingin warm water and multiple cleanings for over 1hr black ink is still coming outof the yellow ink head.
I still get the same message after all I have tried...
One thing I did manage to do is prime the yellow ink and got it flowing throughthe head again but it's still mixed with black... I wonder if you may have runout of magenta and dried the head...
Try priming the magenta ink by removing the head (don't touch or wet the metalcontacts at the rear, the ink heads are on the bottom) place on a clean lintfree cloth (or I just used damp tissues then dry tissues) you should get onelong black strip and two cyan, two magenta and two yellow strips on the tissue,if you do not then try priming by replacing the magenta cartridge and gentlypumping the cartridge up and down repeat until you get the ink flowing.
Replace the head and cartridges, press ok, turn the printer off then reset.
Let me know if it works or if you come up with another solution that works as Iam still trying to figure out how to fix mine.
Good luck
Dec 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error message: Incorrect Printer cartridge, when
the printer scan whatever been placed for it, so if you place a color it will read color and so on…now the printer read that the b lack cartridge is wrong according to your investigations, then the issue is between the ink cartridge and the printer scanner, so take out the black ink cartridge and do the followings, remove any type of materials that may cover the ink tank and make sure that he vent hole is clear, put the ink back after doing the same to the color and cleaning the inside housing, then use the software for self cleaning and alignment..
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Sep 29, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Incorrectly installed cartridges messages
try cleaning them and the place where you put them with a contacts cleaner, this must solve your problem.
Aug 13, 2009 | HP PhotoSmart C4280 Laser Printer
Right cartrige incorrect
This error means that the printer is unable to read or load the cartridge.
Try to rub the golden parts on the cartridge with a smooth damp cloth.
And in the contacts where the cartridge has to be placed also clean it.
Now install the cartridge & check.
Are you using the compatible cartridge with the printer, this message will came if the installed cartridge is not compatible with the printer.
Check with the known good that is the cartridges which you know that worked with the printer to make sure that there is nothing wrong with the printer.
If the error message comes call the manufacturer to checkand replace the cartridge.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
I keep getting an error message- unable to clean....I just bought and installed new ink cartridges, and the machine is still having trouble - I cannot print at all now. There seems to be no way to clear...
The waistinktank has to be replaced. DO NOT only reset the code but change the waistinktank! Otherwise ink will flow into the machine and will cause serious damages!!!!!!!! See link how to do that: http://www.fixya.com/support/t202485-cleaning
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
Open Questions:
Lexmark MFP-X3470 All-In-One InkJet Printer Logo
442 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
