Question about Optics
Why will my crosshair not raise up and down on my leopers scope
I have a leopers scope and the crosshair will not raise up and down and there is no lock on it to unlock it.
  • 243 Answers
The cross hair is located in an erector tube and will not move in your view even when the point of impact moves.
Posted on Jun 24, 2014
  • 117 Answers
SOURCE: crosshairs on pentax 4.5x14x42 don't move
With modern rifle scopes the crosshairs do not move.They are designed so that the crosshairs are always centered.I have not seen a scope with crosshairs that move for about 40 years.If your scope has 1/4 minute clicks, then the strike of the bullet moves 1/4 inch at 100 yards for every click.1 inch for 4 clicks and so on.If you rifle shoots 6 inches high at 100 yards you should turn it down 24 clicks to strike dead on.Many hunters and shooters adjust their scopes to strike 1 1/2 inches high at 100 yards.Then it will be accurate to about 300 yards without further adjustment.
Posted on Mar 25, 2009
  • 5 Answers
SOURCE: i have recently aquired a rifle scope,no name on
clean it, if that doesn't work they have adjuster between the power selector and the tube of the scope
Posted on Sep 14, 2009
SOURCE: how to use accutrac 2x7 redfeild scope
Looking for instructions on the use of an Acu-trac rifle scope by Redfield. There are lines above the crosshairs and a yardage graph on the bottom of the crosshairs.
Posted on Oct 19, 2009
SOURCE: NEED REPLACEMENT PART FOR TASCO 4X15 I NEED THE CROSSHAIR PIECE
im sorry but the price of that scope is not worth getting new crosshairs, you should just go get a new scope at walmart. they are like 9 bucks. But i myself would get a better scope, you can get decent ones for liek 60 bucks. Last a lifetime if you take care of them. The best scopes can cost 800 dollars on up. Just get a new scope. the part would coast more then the scope.
Adrian762
  • 425 Answers
SOURCE: 3-9x50 BSA Deerhunter Rifle Scope.
What that means is they are not mounted correctly. The scope mounts should be square with your rifle when fitted, when the scope is placed into the mounts, it should be turned to be square with the rifle.
Firstly, make sure you do not "cant" when you shoot. That is hold the rifle at an angle instead of vertical. Once you are sure that is OK, then put it into a vice using blanket or some other soft material to protect the stock. Get the rifle perfectly square using a spirit level. There should be a flat spot on the top of the action that you can use. Once this is achieved, you loosen off the scope mounts and square the scope up to your satisfaction. Once done, tighten the mounts up and then remove from the vice.
Posted on Feb 10, 2010
Can adjust scope low enough
Hey Andy..
The scope won't adjust "lower".. lets talk about what you are calling "lower". The "lower" the "crosshairs" go, the higher the gun shoots...and to the opposite end...the "higher" the "crosshairs", the lower the gun shoots...
If the barrel and the scope are perfectly parallel.. when you lower the crosshairs in the front of the scope, the barrel will/must be raised to hit the same spot.. and the opposite is true for the other direction...
......IF this is what your are experiencing,, no biggie..
If this situation above is NOT what you are experiencing, the scope mounts need to be "adjusted" or replaced..
Sep 25, 2017 | Optics
My elevaition crosshair wont raise high enough to raise my point of impact
your crosshair actually needs to go lower to raise the point of impact. if thats what you meant than you have a mounting/scope problem. the scope should naturally align within the adjustment range assuming the mounts are correct and the scope is functioning and mounted properly.
Sep 29, 2013 | Barska Optics Optics
My bsa sweet 17 6-18 is shooting about 2 inches high at 100 yards. on the adjustment turret it has an arrow that shows which way to turn for up. What is moving up? the point of impact relative to the...
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 02, 2011 | Bsa Optics Sweet 17 Target Riflescope...
When I raise the cross hairs on the scope on the graft the bullet goes down and when i lower the cross hairs the bullet goes up is this correct. When I bought my pursuit boar sight from Basspro I only...
That is right. If you had the rifle held in a vice aimed at a particular point and without moving the rifle you raised the cross hairs you would now be aiming above the point. To get your aim back onto the same spot you would have to loosen the vice and lower the barrel of the rifle. This would mean that the next shot would hit the target lower down. The same is true if you lower the crosshairs which means the bullet would rise.
Likewise moving the crosshairs to the left brings your shot to the right and moving them right brings your shot to the left.
Sep 15, 2010 | Sport & Outdoor - Others
Crosshairs moved after rifle was sighted in
now then,,,did the crosshairs move or did the scope slip back out of line? if the mounts were not tight then its likley to be the scope slipping back but if the crosshairs moved were they just setteling or are they moving,,if there realy moving the scope is claped out or shook apart inside,,,how big is your rifle you put this scope on? 357mag??? i have a simmons scope on a 7.62 and on a .303 enfield rifle its ok on them?
Nov 02, 2009 | Simmons Optics
How to use accutrac 2x7 redfeild scope , there are lines above the crosshairs and a yardage graph on the bottom of the crosshairs, how exactly do i use this scope
Oct 07, 2009 | Redfield Optics
Crosshairs on pentax 4.5x14x42 don't move
Feb 15, 2009 | Pentax 4.5X-14X 42mm Pioneer Matte Rifle...
Dec 13, 2008 | Tasco RIMFIRE SCOPES BLACK GLOSS...
Optics Logo
51 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
