Admiral type 848-05
Water will not drain
Admiral washer aav7000aww
If your drain is not high enough, 39 inches, from the ground, it will siphon out. Also if your drain hose is too far down the drain, this will also happen. Just make sure your drain hose in not laying on the ground.
Sep 02, 2014 | Admiral Washing Machines
Admiral LNC6762B water keeps running when starting
try these one of the following is not operating properly.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Oct 19, 2009 | Admiral AAV7000A
I got a washing machine ''Admiral''Model 7010 i can not operate properly. It takes too much water and time as well.coulkd you pls send me the instruction manual so that i could save time and water. thank...
make sure the standpipe the washer drains into is higher than the water level in the machine and that the drain hose is not pushed too far down into the pipe as this may cause syphoning increasing cycle time and water usage.
May 04, 2009 | Admiral AW22 Top Load Washer
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Washing machine
hi there,
sounds like the drain pump. check the drain hose first though, as you may have something caught in it.
Sep 30, 2008 | Admiral AW22 Top Load Washer
Admiral mod#lnc6760b71
Water runs out, but does not spin, nor dry the clothes. Motor is good.
Dec 08, 2007 | Admiral AW22 Top Load Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
