Ge profile model WPDH8800JOMG
Front door is loose
fridgetech
  • 473 Answers
SOURCE: LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Posted on Oct 18, 2007
SOURCE: Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Posted on Oct 10, 2008
SOURCE: loose door handle on ge profile dishwasher
Take the inside panel off.  The 2 screws near the latch only need to be loosened.  Once the handle is off, you will find an allen bolt inside the shaft of the handle support.  Tighten and you are done.
Posted on Dec 31, 2008
woodchuck789
  • 4070 Answers
SOURCE: ge profile refrigerator door stop isn't working
Did it ever work or for some reason you never noticed it before? I've had to swap the door stops to get the door to stop. They can usually be swapped around according to what's needed in different situations.
Posted on Jan 20, 2010
  • 36514 Answers
SOURCE: have a ge profile washer mo.no. wpdh8800jomg need video showing how to put door back together
Check YouTube for something similar.
Posted on May 13, 2017
Ge profile model jcs968skss will not start the cleaning process.
Seems to me you have a relay problem on your control board .you can also have a loose connection to the board in the cleaning cycle side. Bye
Feb 27, 2016 | GE Ovens
My ge profile microwave model pvm1870sm133 is not working properly. when you open the door the cooling fan turns on
Unplug and cease using this as you are exposing yourself to electro magnetic radiation. The door switch may have failed, you will need to disassemble the front panel to access the switch which is located within one of the holes that he door's hooks insert into and depresses to inform the control board the door is closed and is safe to operate.
Dec 22, 2013 | GE Profile Spacemaker 1.8 Cu. Ft....
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
How do I find my model number
On a GE open the fresh food door and it should be on bottom right front corner
Apr 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer door handle loose
Can you give me the model number? Ther are alot of variation of handles.
Nov 14, 2008 | GE Profile PSW26P Stainless Steel Side by...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
