Question about DIRECTV Slim Line DIRECTV SL5 SlimLine Five LNB Ka/Ku Slim Line LNB for Satellite Dish
Searching for a signal satellite in 771 - DIRECTV Slim Line DIRECTV SL5 SlimLine Five LNB Ka/Ku Slim Line LNB for Satellite Dish
I have a Sony MHC-771 mini stereo system with a 3 cd disk tray. I need to replace the belt that operates the cd tray? The tray is stuck in the closed position. Any suggestions?
Remove the belt and measure it in MM. The search for a belt at that size with Google. You don't have to be too precise about the size. For example if it is 48mm than a 50mm belt should do the trick. Don't bother with the maker's name either. Then can be universal. As long as it looks right.
Jan 30, 2017 | Sony MHC-771 Shelf System
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
New customer. Installed yesterday. Worked fine last night. Turned on today, all I get is searching for signal on satellite in 2.... (771).
Go to your menu and find your signal strength bar.It's possible that your dish has shifted.The bar should read at least 60% or above.
Sep 25, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
MENU PICTURE ON TV BUT NO CHANNELS
This is a problem with weak signal strength, You will need to find a better place to put your television so it can receive enough signal to operate correctly. If this does not solve the problem, you will need to check the satellite box for problems with receiving the signal from the satellite. You may need help from the satellite company to check the signal strength output and input levels to make sure its working properly. I hope this information helps you solve you problem with the loss of satellite signal in your television. Thank you for using FixYa and have a nice day!
Jun 18, 2009 | RCA DIRECTV Satellite Remote Control
Error message 771
searching for satellite signal means its not getting a connection between the satellite and the receiver itself. you can check on the back of the receiver where the satellite cables comes in, unplug the satellite cable make sure there is a copper pin sticking striaght up there to make sure its getting a good connection. also if you know where your splitter is, it has a few lines coming in and a few coming out, its somewhere between the dish and the receivers. usually in an attic or basement, or it could be at the dish itself. make sure those lines are tight, no cracks or breaks in the lines. also if your dish is easily accessible check the connections at the dish to make sure none of them have come undone or loose.
Apr 11, 2009 | Directv Plus HDTV Receiver with Integrated...
DTV H20-600
I do not have an schematic for this receiver. This receiver might not use LM317 or TIP42C but a different voltage regulator, try to locate where the 20 volts line from the power supply and follow it to anywhere near the LNB tuner circuitry. This type of IC is normally mounted on a heatsink.
Lastly if you are a subscriber, give you satellite service porvider a call to get a replacement.
Nov 08, 2008 | Philips DIRECTV H20 DTV Receiver
DIRECTV Slim Line DIRECTV SL5 SlimLine Five LNB Ka/Ku Slim Line LNB for Satellite Dish Logo
71 people viewed this question
Top DIRECTV Slim Line Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a DIRECTV Slim Line Water Dispensing and Filtration Expert? Answer questions, earn points and help others
