Question about Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV
I have a Pride Hurricane PMV500 problem - Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV
Shoud light red light flash behind charge indicater when switched on on hurricane
hi, is this still a issue, this is a fault ....
Regards
Rob
www.gewizrepairs.co.uk
Mar 12, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
Where can i get brushes for pride hurricane in uk
I would contact pride or a service centre as if you put the wrong grade of brush in the motor you can damage the comm and motor.
The motors are not cheap.
Mar 03, 2015 | Pride Mobility Products Hurricane PMV...
Speed control on Pride Hurricane
hi, the speed control could be faulty, see if you can spray some Wd40 or contact cleaner in the gap and see if that improves things...is it the one with the snail , rabbit speed sign ?
one bar on the indicator does imply low battery power ...is it flashing ? if it is then that's a fault condition
Regards
Rob
Dec 23, 2014 | Pride Mobility Products Hurricane PMV...
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
My Pride Hurricane PMV will not go forward or backwards when I engage the trottle all I get is a click but it will not move. The battery meter shows fully charged.
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
Nov 03, 2010 | Pride Mobility Products Hurricane PMV...
Pride hurricane batteries (2008,model)
Hi...
You'll get a little more time out of the 55ah ( like 10%)
Mar 31, 2010 | Pride Hurricane 4 Wheel Personal Mobility...
Wiring has been disconnected need to rewire pride hurricane pmv scoote. Need service manual or wiring diagram.
Hello, If you need any manuals or wiring diagrams go to;
http://www.pridemobility.co.uk/ipb/
Username : pride
Password : access
Hope this helps...
Jan 26, 2010 | Hurricane Health & Beauty
Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV  Logo
53 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
