Question about Dehumidifiers
Sears Kenmore dehumidifier model # 106.57500790
This dehumidifier quit collecting water. motor still runs
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
  • 225 Answers
SOURCE: kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Posted on Jul 31, 2008
MNTECH
  • 1543 Answers
SOURCE: not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Posted on Aug 28, 2008
SOURCE: Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Posted on Mar 28, 2009
  • 11 Answers
SOURCE: Kenmore 54501
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Posted on May 29, 2009
The motor runs does not collect water
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 23, 2011 | Kenmore Dehumidifiers
I have a kenmore dehumidifier model # 129-25803. I have no manual and it is collecting water, but not into the tank, but through a hose tucked in behind the tank and it is running everywhere. how do I...
You will need to disconnect the hose and replace it with a screw on cap that came with the unit. With that in place, the water will be diverted into the bucket. If you are missing the cap, you can probably find a replacement at Sears Parts Direct.Be sure you have the correct model number when searching Sears Parts Direct or before calling them.
I hope this helped you. Thanks for choosing FixYa.
Jul 23, 2011 | Kenmore Dehumidifiers
The dehumidifier runs, but does not collect water in its reservoir. (the lights all light up, it cycles on and off, but all it appears to be doing is running the motor - not actually functioning.) And,...
heatman101
Jun 22, 2011 | Kenmore 54701 Dehumidifier
My Goldstar Dehumidifier is not collecting water. There is no air coming out the back. I have cleaned the filter.
Hi, Sounds like the fan quit....could be the board or the fan motor ...check for power at the motor...
heatman101
May 21, 2011 | Goldstar Dehumidifiers
Kenmore 580-54701500 is not working. I noticed a burning smell before it quit. Light comes on control panel- but pressing buttons does nothing. maybe a fan or motor needs to be replaced. not sure if...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 21, 2011 | Kenmore 54701 Dehumidifier
I have a Model 25350650000 Kenmore Dehumidifier. Everything works--motor, fan, lights, won't extract humidity from air
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 22, 2010 | Kenmore Dehumidifiers
My 54351 dehumidifier runs for hours and doesn't collect much wat
I hope someone answers this because I'm having the same problem. Mine is about 4 years old. I thought it was my filthy filter but cleaning didn't change the problem.
Dec 04, 2009 | Kenmore 54351 Dehumidifier
Our Kenmore dehumidifier (Model 580.53650200)runs but no water collects in the reservoir bucket. What could be wrong?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Sep 18, 2009 | Kenmore 5365 Dehumidifier
I have a kenmore dehumidifier model 53701 and it has been working fine, but now no water is collected even though its running. what gives?
heatman101
Jul 14, 2009 | Kenmore 53701 Dehumidifier
I have a Kenmore 54701 dehumidfier, less than 2 year old. the power is on, a fan seems to be running, I no longer hear a compressor turn and, and no water is collected?
The sealed system of the Kenmore 54701 dehumidifier is warranted (Parts & Labor) by Sears for five (5) years. Since the fan in your unit runs but the compressor doesn't, I suggest that you return it to Sears and request (demand) a new replacement unit under their warranty. I say "demand" because Sears will undoubtedly tell you that the problem is due to some "other" component which is not covered, and will charge you mega-bucks to repair it. Been there - - done that.
FYI, read the (very low) customer reviews of these units on Sears website and you'll see you're not alone in your experience with Sears' inferior quality units.
Above all, do NOT pay to have it repaired. That money is better spent on the purchase of a far more reliable brand of dehumidifier - - (which will most likely cost less that what you paid for the Sears unit).
Mar 09, 2009 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
177 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
