Question about Acer AT3705W-MGW 37 in. LCD Television
Screen goes black
Hi there, My TV opening to a light black screen and shuts down. It does not start. It keeps doing this like there is not enough power. Do you have this problem with anybody else. It happens sometimes when there is power fluctuations. It is connected to UPS and stabilizer. Thanks
    Master:
  • 669 Answers
The problem with power fluctuations is the Surge Power that exists when Power Is Restored. That passes excessive current to the TV Controller circuit and can blow the circuit board. Sound like that has happened to you.
IN THE FUTURE...always use a UPS (Uninterruptable Power Supply) approximately 1000 Watt unit. It has a battery back up feature and filters the line Voltage. It protects the appliances and saves you grief. Walmart has them, Amazon too.
Posted on Feb 15, 2018
SOURCE:
  • 4 Answers
SOURCE: monitor keeps going blank at start up
This looks to be a power supply fault - the inverters for the backlights are built into the power supply (Delta Electronics, model no. ADP-40AF).
Posted on Dec 11, 2007
SOURCE: Was dropped. Screen very dim.Keeps restarting.Ideas?
Hello, Paul. Your grandson's notebook's problem could be originated from number of things (caused - or not - by the fall). Let's break it down into two problems (which are probably unrelated): the restarting and the dim screen.
There's a very good troubleshooting guide online by Morris Rosenthal. You can check it here.
About the dim screen
On the aforementioned guide, which i'll be quoting from now on, you'll find particularly relevant information for this case: "Dim desktop image? Can you see a ghost-like image of your desktop that is functional, ie, one that changes if you drag an icon, launch a program or disappears if you shut down. Standard LCD screens produce very little visible light on their own, they require the Cold Cathode Fluorescent Light (CCFL) to light the screen from behind. The fluorescent tube is normally located at the top of the screen, and a bright reflective surface distributes the light across the back of the LCD, so it can shine through the liquid crystals of the liquid crystal display, which only transmit red, green or blue (RGB)."
When you say it brightens, it probably does so in sort of a tinted way.
"Red, orange tint, uneven? Is the entire screen tinted red or orange (probably growing worse over time) or is the background brightness of the screen uneven, particularly near the edges? The tin is caused by a failing backlight not putting out the full spectrum of white light, so the CCFL tube needs to be replaced."
This gives us some information about the backlight that is used in LCD screens, but there's also another component in play, which is the inverter. A damaged inverter is *the* greatest cause for failing notebook screens. Your grandson's notebook's backlight could be fine, but a damaged inverter may not be sending it enough current for it to work. I could only tell you exactly which one is at fault here by running some tests on it, but this information points you to the very likely source of the problem.
About the restarting
This problem unfortunately has a wider range of possible sources, ranging from OS-related problems (like viruses and a corrupt installation), faulty/misconfigured hardware (or drivers), overheating (though the computer usually shuts itself down when it overheats, instead of restarting. It depends on your available BIOS settings) and many others.
I hope this information was helpful, and i advise you to get that lappie checked by a qualified technician.
Posted on Jan 16, 2009
babes_ganda0
  • 381 Answers
SOURCE: Aspire 5315: Loud, Long, High Pitch Beep During Start Up
you need to replace the memory..or try to make clean using a Paper Eraser for make a clean the memory..clean the all pin connectors..good luck
Posted on Jun 25, 2009
joecoolvette
  • 5660 Answers
SOURCE: black screen on acer 242lc lights come on power up
You indicate that the lamp for Power On comes on? (Light bulb icon)
What about the harddrive activity lamp? (Media Activity icon. Looks like a book. Third icon going right, from Light bulb icon)
Is this lamp lit up? (May flash dim to bright) This indicates the harddrive is working.
Yes?
Do you have a floppy disk in the floppy disk drive? Remove it.
No floppy disk? Media Activity icon lamp is working?
Try increasing the Brightness. Hold the Fn key down, (Function key), and press the Right Arrow key.
No?
See if the LCD screen display has accidentally been toggled over to an external display. Hold the Fn key down, tap the F5 key once.
No?
Then it's time to get technical.
The following is not designed to confuse you, nor make it seem like, 'I'm all that, and a bag of chips'
It's a Flow Chart I have used in the past, plus techniques for finding laptop display problems.
[I no longer require using this flow chart]
Do you have an external VGA monitor you can connect for a test? Your laptop has a VGA connector on the back.
[Your VGA connector is in the center, on the back of your laptop]
(VGA monitor looks like a TV. It is a Cathode Ray Tube. CRT)
This is what a VGA connector looks like,
http://en.wikipedia.org/wiki/VGA_connector
(Top photo on right)
Connect the VGA monitor first, THEN, power on your Acer laptop.
Now turn the power on the VGA monitor to On.
You have to toggle your graphics over from your LCD screen of the laptop, to this VGA monitor.
To do this you hold the Fn key down, then tap the F5 key once. (A VGA monitor takes a second, or so to 'Come to life'. Wait a few seconds, see if the VGA monitor comes on. If not, hold the Fn key down again, and tap the F5 key)
Now, do you have graphics on the VGA monitor?
Yes?
Do you have a dim screen?
Try using the Brightness control of the VGA monitor to increase.
Doesn't work?
Then you have a bad Backlight, or a bad Inverter.
(An Inverter supplies the correct power to the LCD screen, and the Backlight.
The Backlight is comparable to a Fluorescent tube, used for normal residential, and commercial lighting. It is a Cold Cathode Fluorescent Lamp. CCFL. The LCD screen cannot be seen without this Backlight bulb)
Requires replacement of these two components.
A Backlight bulb is cheaper to replace than an Inverter. A Backlight bulb is also MUCH harder to replace than an Inverter.
The Backlight bulb is located within the LCD screen itself, which requires dismantling the LCD screen to replace it.
The Inverter is a component that is accessed much easier.
Upon removing the LCD screen from the laptop, then removing the bezel that goes around the LCD screen, the Inverter is located at the bottom of the LCD screen.
I state that both components should be replaced, because I have found that when one goes out, the other is usually not far behind it.
Do not have a dim screen?
Then the connectors for the wires, that supply the video signal, and power to your LCD screen, may be loose.
OR,
1.It could be those wires are broken
2.It could be a bad LCD screen
3.Could be a bad connector on the motherboard, for the wire's that deliver signal, and power to the LCD screen's connector,
or the matching connector on the LCD screen, for those wires.
Do not have graphics, (images), on the external monitor?
Then you have a bad graphics chip on the laptop's motherboard.
Requires replacement of the motherboard.
The above is stated, so that you will know what may be happening with your Acer Travelmate laptop.
It is for information purposes.
It is not a recommendation, nor advisement to repair the laptop.
The only true way of finding out what is wrong with your laptop, is to take it to a competent computer repair shop, and have it diagnosed by a professional.
Posted on Sep 18, 2009
eagle338
  • 4889 Answers
SOURCE: hi ! my tv was working
Does the screen goes black imply that the sound is still working? Please clarify this so that I can offer you a solution.
Posted on Jan 19, 2011
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
WHY TV KEEPS SHUTTING DOWN AFTER ABOUT TWO SECONDS AFTER YOU TURN POWER ON WITH NOTHING ON SCREEN
If the light just goes off then look at the ballast . If the whole set goes off then look at the power supply board.
Jan 24, 2014 | Philips 50P8341 50" Rear Projection...
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
My screen keeps "looping". starts, goes to black
You can try to get the processor to do a cold start. To do this, unplug the power from the set - turning it off is not enough, you must unplug it!
After 15 minutes, plug the set back in and try to power up. If it works OK, you are good2go!
If that did not work, your set probably has a power supply problem. The best option if it is under warranty is to exchange it.
If your warranty has expired, find a good TV repair shop and ask for an estimate before going any further.
Good Luck!
Feb 13, 2011 | LG 50PG20 50 in. Plasma HDTV
Toshiba Satellite - black screen only when plugged in
hi
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTUNUE TO USE YOUR LAPTOP
Jul 07, 2010 | Toshiba Computers & Internet
Acer AT3705W-MGW 37 in. LCD Television Logo
129 people viewed this question
Top Acer Televison & Video Experts
Eric Rotmil
Eric Rotmil
Siul Oyaratgam
Jaime Hernandez
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
