Question about Pool & Spa
How much sand for an aqua tools at3120 - Pool & Spa
How do I paint furniture? I know I have to sand it first.
easy stuff. sand it lightly and go for it. may need two coats
Aug 27, 2017 | Furniture
Where does the small clear hose coming from the
Could you provide more information on the filter. I am not familiar with the "Aqua Pro". Maybe a model number or more from the label?
Sep 19, 2014 | Pool & Spa
WHEN I PUSH THE FILTER BUTTON THE LIGHT COMES ON, THE SCREEN SHOWS FILTER ON , BUT PUMP DOES NOTHING . WAS WORKING FINE PUMP WAS REBUILT 1 WEEK AGO. THIS IS AQUA LOGIC .
check wires in back of pump motor maybe loose make sure all breakers are on and make sure wires going to pump relay are tight you might have a bad pump relay also
Jun 11, 2014 | Hayward SAND FILTER, PRO SERIES
My electrolytic cell and hose have bright aqua chalky feeling substance in them, what should I do and why is this happening?
you have some metals in your water and the cell needs to be cleaned. Aqua color Normally means Copper.
Did you use a Copper Based Algaecide?
Clean out the cell with a high pressure nozzle on the garden hose and a little bit of vinegar splashed on the cell before rinsing.
Aug 25, 2013 | INTEX Sand Filter Pump
User's manual for svp aqua wp5300 digital waterproof camera
SVP product manuals are available from http://svp-tech.com/download.html . The WP5300 camera manual is in a RAR compressed file. You'll need a tool like WinZip or WinRAR, http://www.rarlab.com/download.htm , (for Windows OS). These tools offer trial use versions for 30-40 days which will allow you to uncompress, read and save the PDF.
I hope this helps.
Jun 09, 2012 | SVP Aqua WP5300 Digital Camera
Aqua swim 520
How much sand or glass go into this filter. We have to replace ours
Feb 26, 2012 | Pool & Spa
How to remove pump from motor
remove the bolts holding the suction side cover on. remove the cover on the end of the motor and use a tool (armature holding tool) to immobilize the motor shaft. remove the center screw (if applicable) in the middle of the impeller by turning clockwise. Spin the impeller off by turning counter-clockwise. If it will not come off, you may need an impeller wrench. Once the impeller is off you can remove the four through bolts and the motor should come right off.
Oct 30, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Where can I get a manual for Culligan Aqua Cleer?
I found the manual for an Aqua Clear AC15 at the following web site. Go to the below web site and locate the filters for your system. There will be a link to the manual in a .pdf format.
http://www.freshwatersystems.com/s-69-culligan-water-filters.aspx
May 15, 2010 | Culligan Under Sink Water Filter
How much sand goes into a waterco t600 sand pool filter
Hello. 265 pounds of sand required. Here is the link
http://www.aqua-man.com/row_num.asp?ic=51945&froogle=1
please rate my answer as very helpful. thanks. Joe
Mar 31, 2010 | Garden
Pool & Spa Logo
105 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
