Question about ASUS Bios Chip:K43br, K43sa, K43sd, K43sm, K43sv, K43ta, K43tk
Recovery bios asus k43sd
I have ASUS LAPTOP K43SD. I tried to update BIOS, finished but after it the LAPTOP has a problem. The power is on,
5 Suggested Answers
  • 1257 Answers
SOURCE: remove password from award bios on asus laptop
Click on the link below and follow the instruction
http://www.fixya.com/support/r1257563-break_bios_password
Posted on Nov 17, 2008
sodeep
  • 3267 Answers
SOURCE: Asus P5VDC-TVM Bios update
Please do not update BIOS unnecessarily. Only when you face problems and the error message request for BIOS update only then do so. On asus site enter all the required details & try, but my advice is to leave it alone if its in working condition....sodeep
Posted on Mar 20, 2009
shibuda
  • 1812 Answers
SOURCE: I've AMD Athlon 64 bit
you must plug in your pc with ups
do step by step from internet and alwayas choice last date
http://support.asus.com/technicaldocuments/technicaldocuments_content.aspx?no=714
for download =http://drivers.softpedia.com/progDownload/Asus-K8S-MX-Bios-1013-Download-13287.html
1st thing you'll need to do is go to the motherboard manufacturer's website & download the new BIOS file & the flashing program. These 2 files will have to be copied to a bootable floppy, then you'll have to boot off it & do the update from DOS. The motherboard website should have a detailed explanation on how to perform a flash...print out the instructions & follow them exactly & you should have no problem
Posted on Nov 12, 2010
mastericpr08
  • 571 Answers
SOURCE: I forgot my bios password
need to open the laptop and remove the BIOS battery and put it back after 10 seconds
Posted on Nov 24, 2010
Why my batterie ndo not charge?
See if you can find someone with a Asus that takes the same battery, to see if it will charge on theirs. I check the ASUS website and there are upgrades for the BIOs. But non that talk about the problem you talk of. ASUSTeK Computer Inc Support Drivers and Download K70IC
I take it that the ASUS runs okay when powered by the power supply, so it most likely the battery is bad. Not the laptop, but I suggest you try to find someone that also has an ASUS that the battery will fit. So you do not waste money, if the motherboard charging unit is bad on your laptop. P.S. your laptop can run without a battery installed.
Your question on BIOs upgrade How to can be found on the ASUS site as well. They have a video if needed to done. It's not hard to do, but you do need to be sure you understand the instructions clearly. The BIOs you would upgrade to is the one with the newest date. BIOS 211
Firmware change 2010.07.22update
May 20, 2014 | liion 4400mah Li-ion Battery For Asus...
Asus motherboard bios recovery
Ekse
Rank:guru_s.gif Guru
Rating: 85%, 1169 votes
In the disk you burned, the bios can't read a zip file, the file needs to be extracted and as far as I remember you need to use a diskette instead of a cd. but I will look into it now.
Comment by Ekse, posted on Aug 07, 2008 Bios warning
Please note, BIOS update is only recommended when experiencing technical difficulties with your system, And is not recommended to be performed regularly.
Moreover, due to the nature of BIOS update, there is certain level of dangers involved. BIOS update must be performed with extreme caution . During BIOS update process, your system must be maintained without interference or power loss to prevent unexpected damage.
In case of BIOS update failure, please follow instructions in your User's Manual for guidelines on BIOS recovery via CrashFree BIOS. In the event that BIOS recovery is not recoverable via CrashFree BIOS, please contact your place of purchase for further assistance on BIOS recovery.
Source Asus
You can get the bios from here
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4V8X-X
Get the 1008 version
its under Bios and 3rd entry, all os version 1008
File is in zip format, needs to be extracted.
the rom file inside needs to be placed in a diskette.
Comment by Ekse, posted on Aug 07, 2008 Diskette or if you can get the bios to read a cd then that is fine also. Comment by Ekse, posted on Aug 07, 2008 if the setup is looking for a file named as
P4V8X-X.rom
it may be required to rename the PV8XX08.rom to P4V8X-X.rom
But im not perfectly sure what you are trying todo or why it is asking for it. il have to look into this more. Comment by Ekse, posted on Aug 07, 2008 As I suspected, BestDarnGood linked us the manual and the correct page about the problem. it confirms that the file has to be renamed and placed in a floppy.
Thanks BDG
http://www.fixya.com/support/p362915-asus_p4v8x_x_motherboard/manual-11149/page-39
Aug 07, 2008 | Computers & Internet
Asus k43sm doesn't boot after application of thermal paste
If you put thermal paste on the processor, you need to recheck the processor to be sure that it is seated right, no pins are bent and that the ZIF socket is put back in locked position. If this was not the processor that you put the paste on, then it might not be electrically neutral and you have shorted it out with the wrong paste.
Apr 08, 2014 | ASUS Bios Chip:K43br, K43sa, K43sd, K43sm,...
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
How can i open my asus laptop when master password disable
If you set BIOS Passford, for some reasons it doesnt bipass, the only way to reset is to open laptop (Disassemble) where you need to take RTC (Real Time Clock)Battery for couple of min and reinstall. This process make all the settings in the BIOS to RESET. Hope this help.....
Dec 08, 2012 | ASUS Bios Chip:K43br, K43sa, K43sd, K43sm,...
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Failed bios recovery on ASUS P5S800-VM using support cd
Hi there.
If you look on any support/bios update forum/website, you will find that flashing the bios is very risky. The reason it's risky is because of what you just described.
While flashing the bios, the bios chip memory is deleted and then the new bios is written. If you lose power, system crashes, or anything that interrupts the flashing process, the chip is rendered useless.
The computer turned off while flashing, and the reason there is no screen is because there is no bios to load. There is no way to reverse this or repair it.
If you are handy with a soldering iron and are confident with electronic components, you may be able to pick up another bios chip on the internet, but you will have to solder it to the board yourself.
Otherwise it's a new motherboard.
Sorry it wasn't good news
Mar 25, 2009 | ASUS P5S800-VM Motherboard
BIOS Password Problem
The only thing that a bios update would do would update the bio your password info should stay the same maybe your not typing it right try typing with or without cap lock
Mar 10, 2009 | ASUS F9S-B1 Intel Core 2 Duo T7500 2.20GHz...
Asus mother board bios
what model is your motherboard? try searching for it on the internet. What is the symptom on the motherboard now? Is it accessible ang operating? Let me know so that I can help you further. Goodluck!
Sep 17, 2007 | Intel Motherboard
ASUS Bios Chip:K43br, K43sa, K43sd, K43sm, K43sv, K43ta, K43tk Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
