Question about ProMariner Advanced Onboard Chargers Model Prosport 8,12/24volts, 8 Amps,2banks
WHEN I PLUG MY PRO SPORT 12 IN THE POWER BLUE LIGHT JUST BLINK ON AND OFF---IT HAS BEEN WORKING FINE UNTIL A FEW DAYS AGO
My Coby LEDTV-2426 24 No Power
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 19, 2012 | Coby LEDTV2426 TV
The truck stalled a few days ago. It was jumped and ran fine. Yesterday it stalls again, but won't the battery won't hold a charge. It was towed to the shop and they said everything tested fine once they...
sound like might have a prooblem with the charging system. if the altenator is not charging the battery while driving then when the battery voltage gets too low (prob around 10volts) then the computers will shut down, then when jump started it gets some power back, and when the battery is charged will all work fine for a while.
does your model have the voltage gauge in the dash? should be over 12 volts when engine running, 14volts is a good charge rate. and should stay up above 12 all the time, with lights on air condon etc...
and altenators can be funny, work sometimes, and not atother times,
Mar 24, 2011 | 2002 Mitsubishi Montero Sport
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Blinking power light - router not working properly
Blinking power light on the Linksys routers indicate 2 things. 1st is firmware problem, 2nd is the worst one which is defective router. You can still revive it if you can reload the firmware. If not, it's a dead one and you need to purchase a new one. And man, your router is a very old one. You must switch to wireless G router, its 5 times faster than your wireless B and it only cost 30 or 40 bucks
May 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Worked fine for a year, now not recognized or functioning
I had the same issue- light was blinking from red to blue, could not get my computers (I have a Mac and a PC) to recognize the drive, sounded like the drive wasn't powering up...
I replaced the Acom drive enclosure with a new one (CP Technologies). I don't know if the drive enclosure or power supply was at fault-- but it wasn't the internal drive. Plugged it in and amazingly all my data was back. For thirty bucks it was far less than sending out the drive to a 'data recovery' expert!
Jun 09, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Sep 13, 2007 | Mitsubishi WD-62525 62" Rear Projection...
ProMariner Advanced Onboard Chargers Model Prosport 8,12/24volts, 8 Amps,2banks Logo
121 people viewed this question
Top ProMariner Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a ProMariner Boating Expert? Answer questions, earn points and help others
