Question about Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Do i need a digital converter for lc-260v24u - Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
2 Suggested Answers
  • 42 Answers
SOURCE: Do I need a digital
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Posted on Mar 09, 2011
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
I have Advent LC-15Y26 LCD tv. Does it need a digital - analog converter?
I have one as well and it only tunes in analog (old over the air) t.v. signals. If you want to receive the digital signals, you will need an external tuner/converter box.
Jan 21, 2011 | Recoton Advent L2711A 27 in. LCD...
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My walkman can't read the format:mp4
Your Sony Walkman will only read/play the following formats...
Supported Audio Format: MP3, WMA, AAC-LC, Linear PCM
Supported_image_format: JPEG
You will need to convert your songs/files to one of the above supported formats before they will play on this player.
You can download a free song/video format converter at the following website:
http://www.formatoz.com/
Good Luck, I hope this helps...
Nov 23, 2009 | Sony NWZ-S616 Digital Media Player
Does my LC-13S2U have a digital tuner?
Going over you manual for the tv, it doesn't have a digital tuner.
You'll need a digital converter box for broadcast channels.
Indoor antenna will work. But, an outdoor antenna will work best for reception.
If you need a copy of your manual, you can download one with this link:
http://www.sharpusa.com/files/tel_man_S2Useries.pdf
Jun 14, 2009 | Sharp Aquos LC-13S2U-S 13 in. EDTV-Ready...
Dont have cable. i bought the analog converter, but read i don't
Digital Ready is not the same as having a digital tuner built in. Yours is probably the former and you do need a converter box: http://www.ezdigitaltv.com/HDTV_vs_HDTV-Ready.html
May 04, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Does the Sharp Aquous LC-13E1U receive digital or analog broadcas
It looks like your TV is not HDTV capable, so you will need a box when the conversion takes place next year unless you have cable box or satellite TV receiver.
Dec 20, 2008 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
Analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Sep 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
