Question about Timex Womens T21854 Classic Stainless Steel Bracelet Watchwith Expansion Band One Size Fits All
Remove links from timex watch band - Timex Womens T21854 Classic Stainless Steel Bracelet Watchwith Expansion Band One Size Fits All
indays
  • 111 Answers
SOURCE: timex data link band
good morning ! remove the spring bar carefuly to remove the band on your timex data link ! use screw driver to open the case back ! be verry careful to do that ! thanks !god bless !....
Posted on Sep 04, 2008
  • 492 Answers
SOURCE: Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
Posted on May 09, 2009
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
escapement
  • 2334 Answers
SOURCE: How to remove links on womens t26301 watch band
Read my tips, plz.
Posted on Jan 18, 2010
mcdevito75
  • 1970 Answers
SOURCE: my timex indiglo watch's
mcdevito75 here, Removeing the tiny pins to remove links is fairly easy, replaceing them is the hard part, for this you"d need a Link remover tool, Best Bet is to look for a small watch repair shop in your area, the $10--15.00 cost will equal your Time, effort and tool you"d need. Don"t forget to hold onto the links removed from the band in case you need them again.
Posted on Feb 09, 2011
How to remove watchband on timex atlantis 100
On this link you can see how to resize and remove the watch band.
You need some tools.
Resize your Watch Band and Remove Links with Basic Tools
Jul 21, 2014 | Timex Atlantis 100 77517 Wrist Watch
HOW DO YOU REMOVE A LINK FROM THE BAND OF A T2M932 TIMEX WATCH
You need a small mallet and pin, to hammer out the holding pin, the band has little arrows on the inside indicating direction, remove the one right next to the buckle so that watch keeps its normal appearance...
Good luck.
Aug 19, 2011 | Timex T2M932 Watch
I need a replacement band for a timex data link 53722. This is a unique shaped resin band.
one thing i know when it comes to timex band, you have to place an order on it's authorize retailer. because that kind of watch didn't have anywhere but timex only. i hope i had been helped you.
Jul 22, 2011 | Timex Advanced Data Link 53722 Wrist Watch
Band too large . How do I shorten an expansion band that does not have pins? It is the Timex Easy Reader
You din't. Take it to a jeweler and have them do it for you. If you've never removed links for an expansion band you'll destroy it in the process.
Jun 08, 2011 | Timex T26451 Classic Expansion Band Watch...
My timex indiglo watch's expansion band is too large. How can I remove links to make it smaller.
Feb 09, 2011 | Timex Indiglo Expansion Watch
Adjust Watch Band
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Feb 24, 2010 | Timex Ironman Triathlon Hi Ti Watch,...
May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
Timex data link band
Aug 29, 2008 | Timex Sports Ironman Triathlon 100-Lap...
Timex Womens T21854 Classic Stainless Steel Bracelet Watchwith Expansion Band One Size Fits All Logo
56 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
