Haier 12,000 portable air conditioner high pitch squeal
  • 74 Answers
SOURCE: Air handler squeals
Squealing sounds from a forced-air heat pump generally occur when the belt that connects the motor to the fan slips. If the blower is making a grinding noise, shut off the unit and call a heat pump repair technician --the motor's bearings are probably shot. In most cases, the belt is improperly aligned or worn and needs replacement. Follow the instructions in your owner?s manual (if you don?t have one, contact the manufacturer and ask for one). This job involves removing the access panel, loosening a couple of bolts that hold the blower motor at the proper tension, and realigning or adjusting the belt. In many cases, it?s a good idea to remove it and buy a replacement at the hardware store. When reinstalling the belt, be careful not to over-tighten it--this can wear out the motor bearings.
Posted on Jan 18, 2006
SOURCE: Error code A5 on Frigidaire
I have a Frigidaire model FAK104R1V window air conditioner that did the same AS error code. The problem is going to be one of the 2 temperature sensors in the unit. Mine happened to be the ambient temperature sensor located at the front of the unit. They are fairly easy to replace and you can buy a new sensor for about $15 online.
Posted on Jun 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
kaycee71
  • 37 Answers
SOURCE: I have HAIER HPAC 99ER Portable air conditioner
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Posted on Aug 28, 2009
SOURCE: Haier 12,000 portable unit. Red light comes on STOP appears
Drained tank then operated fine
Posted on Oct 08, 2009
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
How long should the compressor stay on? mine stays on for (5) minutes,then stays in fan-mode
Kindly check your temprature settings and ventilation of outdoor unit. Your compressor is getting hot either due to low ventilation or your temprature settings are too high to cool.
Sep 06, 2014 | Haier HPF12XHM-LP Portable Air Conditioner...
SearchSTOP KEEPS BLINKING
I had this issue as well, what I did was took it off a surge protector and directly into a double wall receptacle with nothing in second outlet, boom my worked. Good Luck.
Nov 19, 2013 | Haier 12,000-BTU Commercial Cool Portable...
STOP KEEPS BLINKINGsearch
Why is it leaking an it keeps soaking my floor please help
Some portable air conditioners have either poorly designed provisions for ducting condensate outside or NO provisions at all. In a recent case, the solution was to place a pan under the unit to collect condensate and allow it to evaporate before overflowing
Jun 11, 2013 | Haier Cpn12xh9 Commercial Cool Portable...
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
