Question about Kitchen Ranges
Manual and user guide for newworld 444445703
Does the same guide apply to new world lpg gas cooker 444448231
SOURCE: Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
Posted on Oct 08, 2009
SOURCE: new world gas cooker (apex hl 500)
the battery compartment is located right at the bottom of the cooker on the front, slightly to the left. It's a little compartment that houses a aa battery. it's unclips on the right hand side. hope this helps
Posted on Oct 15, 2009
  • 3 Answers
SOURCE: can you help me find a user guide for leisure
I could copy my handbook of the Users Guide for a Rangemaster 110 Gas appliance if you wish and send it on to you, if that would help.
Posted on Oct 23, 2009
SOURCE: I have a rangemaster 110 LPG Hob and double oven
Hi, a complete shot in the dark as its a while since you posted - we have a mains gas rangemaster 110 and need an LPG one, do you still need to change or have you sorted it now? Cheers
Posted on Jan 26, 2010
johnrodgers1
  • 73 Answers
SOURCE: How to replace a thermocouple in a New World
not at all hard to replace just have a few small wrenchs on hand 10mm 7/16 maybe 1/2 in and screw driver. how do you know its a thermocouple problem, theremocouple are on commercial ovens and basic ranges usually a domestic range has a glow coil operating oven and not a thoemocouple
Posted on Feb 05, 2010
Adjusting Air/Gas mixture on a Glem Gas cooker
The only change I know of is a jet change, from bottled gas to natural gas . it may pay to have the regulator pressure checked .
Aug 03, 2015 | Kitchen Ranges
My newworld newhome cooker's ignition does not work. Please could you tell me where the battery goes as I cannot find it.
The battery is in a case (plastic holder) left hand side right near the floor in the plinth, opening the oven door will make it easier to see. (Assuming I have the correct model)
Dec 09, 2013 | New World Ovens
How to change bulb on newworld g90 vision cooker
To change the bulb is quite easy, the glass lens screws off, give it a good soak and clean whist popping out to buy a new bulb, otherwise you won't notice the difference. Note the bulb is a special oven bulb, if yoo can't read the old bulbs rating it's probabily a 25W 230/240V rated for 300deg C - try Wilko's around £2.50
Sep 18, 2010 | New World G90m Gas Double Oven
There is a strong smell of gas from my cooker, pipe from cyclinder to cooker appears ok , new world 55wlg
Do not light anything if you are smelling gas. Make up a soapy solution in a spray bottle and apply to all connections and look for bubbles. Most common place to leak is hook-up at cylinder and hook-up at cooker. If you can't find the leak and continue to smell gas, do not use it. Also make sure your cylinder is not empty.
May 15, 2010 | New World 55WLg Gas Kitchen Range
Moved into a house with a New World 60EDOm fan oven and electric cooker, but we are missing the manual, would it be possible for us to be sent one?
Hi please would it be possible to have the manual for the Newworld 60edom, I have a problem with one of the rings on it seems to come off and on. Can not locate the manual anywhere.
Many thanks
Nov 29, 2009 | Ovens
Natural gas to LPG conversion kit for old new world gas stove
Silver solder up all burner jets and redrill to .6 mm then reset adjusters so you get a nice blue flame with small orange tips.and oven burner to .8mm i have just done a new world 75 last week.Works perfect
Apr 14, 2009 | Ovens
Kitchen Ranges Logo
14 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
