Question about AMD Motherboard, nForce4 SLI, S939, Athlon 64/64FX/64X2, Max. 4GB DDR, 8 SATA, 2 IDE, GBE, 1394a (NF4SK8AA8EKRS)
Upgraded system keeps rebooting before going into windows
I upgraded my computer, everything seems to be recognized in the start up but just as it is about to go into windows, the system reboots. The motherboard is a winfast NF4SK8AA. Can anyone help me ? Thanks Straw
    President:
  • 2,961 Answers
What has happened is, because you have upgraded, XP can no longer find the registered serial hardware numbers of the parts you have removed, especially if it's a new motherboard. You will need to repair the windows files by way of using your XP disc. When there are major changes in hardware you have to set your cmos to boot from cdrom, insert your XP disc and when the option to boot from disc shows press enter. Allow the cd to install the installation files, but when prompted instead of pressing enter to install windows, press 'R' to repair instead, at which point your C: drive will be shown, press 'Y' to answer yes to the c drive that needs to be repaired and press enter and allow a system repair, no docs or files will be lost as you are only repairing not formatting and installing.
Posted on Aug 11, 2007
    Guru:
  • 120 Answers
Did you upgrade to a new motherboard? If so you need to completely reinstall windows.
SOURCE:
New Hard Drive - can someone help please?
Yes, you could do that if you take the HD out if the laptop and install in the Desktop temporarily.
I wonder if the bad HD is still plugged in. If so, that could be your problem; make sure it's not connected and seen before the new HD.
May 15, 2018 | The Computers & Internet
Hi my HP failed to restore factory settings and now will not start, an error page come up at the begining "windows failed to start, a recent hardware or software change might be to cause". it...
Try booting into safe mode. press F8 immediatly after the logo screen disapears when you start up your computer. see if you can get in that way. if you are able to get in try using a restore point. sometimes this is caused by software that requires making system changes such as office when it creates the "one note printer option" you can try using "msconfig" from the start>accesories>run then typing msconfig then hit enter. under general tab select " selective start up and uncheck everything but "use original boot configuration. then under boot tab uncheck everything. reboot and see if you can get in. otherwise you are going to have to contact HP. if you have changed or upgraded the video or sound card this might happen as what the factory restore actually does is completly erase, format and copy (not install) a pre-installed windows installation from an image located on a recover partition. if you have infact replaced or upgraded anything ( other than Hard drive this will not cause your problem) remove them and do restore again. then after successful factory reset reinstall one, install drivers, reboot make sure works then install other, rinse and repeat.
Nov 04, 2010 | Computers & Internet
Upgraded the BIOS and no more DVD Device manager
If you cannot see the DVD Drive you have lost the DVD drivers....
relode the drivers from your system provided CD and reboot
and even check in the "safemode "network support" by pressing F8 contunisly......as soon as you switch on the laptop ...
Sep 19, 2009 | Acer Aspire 5520-5908 Notebook
I have recently upgraded my ram from 516 to 2 x
Try installing one module only. (You may have to try in first slot, and then if it does not work, in the second slot.) If the 1gb module is recognized install the second one.
If all else fails, the modules may be incompatible with your motherboard, or 1gb exceeds the capacity of the slot.
Hope it helps
Aug 29, 2009 | Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Constantly rebooting
call me craxy, but you may need to replace your power supply, and if its not that, it is a stuck or broken fan on your graphix card or your cpu.
Dec 29, 2008 | E-Machines (T2958) PC Desktop
New Motherboard Problem
I believe you have a driver conflict
Check your BIOS is set for CPU etc.
And Uninstall all drivers And see if computer start with only the windows drivers present.
As if you have just installed windows and no M/board drivers.
And reinstall M/board drivers one at a time Should fix your problem
Nov 03, 2008 | Intel Motherboard
Firmware Upgrade Problem
the code 37,024.42 suggests a hardware failure
according to the error code manual
https://www.office.xerox.com/partners/products/Phaser8500/SQRG/03_error_codes.pdf
Drum heater relay board disconnect.
Both drum heater relay coils are not drawing the expected power from the supply.
I hope this helps
Sep 27, 2008 | Xerox Phaser 8560MFP Laser Printer
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Rebooting and rebooting and rebooting
Hardware issue then - this player must be replaced. Make sure you have tried all of these methods first:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 30, 2008 | SanDisk Sansa e260 MP3 Player
AMD Motherboard, nForce4 SLI, S939, Athlon 64/64FX/64X2, Max. 4GB DDR, 8 SATA, 2 IDE, GBE, 1394a (NF4SK8AA8EKRS) Logo
74 people viewed this question
Top AMD Computers & Internet Experts
Ekse
Alun Cox
Carlo Barzo
Carlo Barzo
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
