Question about Philips IPF-174 Plain Paper Inkjet Fax
Not able to phone out from extension phone
I'm stuck with this problem and have tried things including resetting to factory settings. I have a home telehone system with the fax being the first device on the line. I also have a panasonic cordless telephone plugged in to the same socket -serial connection I belive. When I try to telephone out using the cordless phone it rings but when the person picks up the line gets cut off! Any suggestions?
  • 59 Answers
Try plugging the phone in the handset jack of the fax
Posted on Aug 13, 2007
SOURCE:
LG LS970 wont reset stuck on system screen wont show keyboard
take the battery out of it and start over..
Jan 12, 2014 | Cell Phones
I do not know the passcode for my phone
Resetting Phone Settings
Resetting the device restores all of the factory defaults,including the ringer types and display settings.Onboard data such as Contacts, History, Scheduler,and Messaging are not affected.
  1. Press Home and touch Main > Settings > Reset> Reset Settings. (A disclaimer is displayed.)
  2. Read the disclaimer, write down the lock code, and touch Proceed.
  3. Enter the lock code provided on the disclaimer by using the onscreen dial pad.
  4. Touch Done to reset the device's settings.
Resetting Phone
Resetting the device restores all of the factory defaults,including the ringer types and display settings and deletes all content stored on the phone.
  1. Press Home and touch Main > Settings > Reset> Reset Phone. (A disclaimer is displayed.)
  4. Touch Done to restore all factory settings.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.*Disclaimer:Performing a master clear/master reset/hard reset will erase all your data (photos,videos,contacts etc) completely and reset all the settings to Factory default. The information contained in this website is for general information purposes only.In no event will resetcellphone.com be liable for any loss or damage including without limitation, indirect or consequential loss or damage. For complete disclaimer notice please visit Disclaimer. The brand names are the registered trademark of respective manufacturers.
Sep 06, 2012 | Samsung SPH-M800 Cell Phone
My optimus is stuck on the android screen
Hi
Try removing the phones battery and re-inserting it.
Solved?Try resetting the device to its original factory settings.But be warned,all data including third party applications will be lost.
Hold the Home and Volume Down button.
Press and hold the Power button until it powers on.
Follow the on-screen instructions to reset.
Feb 28, 2012 | LG Optimus GT540 J1
How to delete everything off htc eris
From http://www.htc.com/us/support/droid-eris-verizon/help/settings :Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press Home > Menu, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the Volume Down + Send + End buttons. The reset process will start after a few seconds.
Dec 30, 2011 | HTC Cell Phones
Its keeps force closing nearly everything
If you've tried to update your phone's firmware and it failed or installed something that is not compatible with your device (bogus application) this can happen. Only thing you can try is factory reset (it is easiest way).If you can enter your phone settings and under privacy tab, you can select factory reset. If your phone keeps force closing and you can't go to your settings, you will have to enter recovery mode.There are a few ways to enter in Recovery Mode -> video link. Once in a recovery you can easily choose Factory Reset. On upper link you can find three ways to do it, and one way of doing it goes like this, it usually works:
1. Power Off your phone 2. Press and hold Volume Up button + Power button + Home Menu button (just hold all three buttons at same time until logo appears) 3. Select Wipe all data / Factory Reset (you select it with Volume Up and Volume Down buttons and execute it with Power button or in some cases with Home Menu button).
If you watch videos you will find same thing.
Jul 31, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do I reset my lg optimus
See the instructions below how to factory reset your LG Optimus
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your LG Optimus T is frozen, pull the battery out and reinsert it
  2. Hold the Home and Volume Down button
  3. Press and hold the Power button until the device turns on
  4. Follow the on-screen instructions to reset your device
All data including third-party applications will be deleted from the LG Optimus T. Once the wipe is complete, the phone will reboot to its factory fresh state.
Amardeep
For More Tips, Visit My Blog @ http://thegeektweet.wordpress.com
May 27, 2011 | LG Cell Phones
The process com.android phone has stopped unexpectedly. please try again. This message comes up on 90 % of my incoming calls. Force close ? Any ideas Thanks
I would start with a Master Reset. That's the best place to start.
Pulling the battery doesn't really do anything but fix little problems.
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press HOME > MENU, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the HOME, END CALL/POWER, and BACK buttons. The reset process will start after a few seconds
Mar 29, 2011 | HTC Hero Smartphone
Lost panasonic KXT-7730 password
If you lost the password the only way to get into programming mode is to reset the telephone system to factory default. If you are not accustomed to all programming features this is not recomended because resetting will whipe out all programming including ringer settings, extension names, speeddials, routing and class of service. If you still want to reset let me know.
Dec 10, 2008 | Panasonic KX-T7730 Corded Phone
Philips IPF-174 Plain Paper Inkjet Fax Logo
153 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Damen Wong
Damen Wong
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
