Question about Panasonic VIERA Televison & Video
Turn off internal speakers
TC-55ST60 shut off internal speakers so I can use my speaker system.
  • 124 Answers
SOURCE: need to turn external speakers on (ilo tv)
What is the model of the DVD player and the Television.
Posted on Nov 12, 2008
SOURCE: I lose Audio from internal speakers Vizio
This issue is actually caused by my cable box. Access the audio SETTINGS on Hand held Cable Remote, and turn on the HDMI and or "Digital Audio Out" option. found on 'more' settings list. This should fix the issue. I had assumed the Cable companeis 'Boot' would have installed this feature during its initialization.
Posted on Dec 20, 2009
bobhifi
  • 635 Answers
SOURCE: Panasonic TC-32LX60C LCD TV Internal Speakers have
Please check in the Menu under Audio section if you can disable the internal speakers. In the Sony and Samsung TV's you can. It will be in the bottom of the of the audio scroll Menu.
It will ask you TV sound Internal / External ?
Choose internal
Posted on Apr 01, 2011
budmrtn
  • 11361 Answers
SOURCE: is there a way to
User manual:
http://tv.manualsonline.com/manuals/mfg/osram_sylvania/6632lg.html
Please look at the on screen setup/sound setup.
Posted on Jun 12, 2011
gopakumarg43
  • 74383 Answers
SOURCE: Control volume on external speaker system
There is no control for this in the TV. You must do it with the volume control of the external amp.
Posted on Aug 21, 2012
Panasonic p42g10a how do I turn the tv speakers off to run home theatre system?
There is usually a location somewhere in you customer menu where you can turn the internal speakers off.
Page 34 of the owners manual.... http://service.us.panasonic.com/OPERMANPDF/TCP42G10.pdf shows "speakers" you should be able to turn them off & on there.
Jul 24, 2014 | Panasonic TC-P42G10 Plasma TV
Just Purchased TV and called Panasonic to answer this question. In short, there is not an option to disable the internal speakers!
Aug 09, 2013 | Panasonic VIERA Televison & Video
Panasonic TC-32LX60C LCD TV Internal Speakers have never worked. Had audio hooked up through surround system. It's now a spare TV. How do I get audio through the speakers?
Choose internal
Apr 01, 2011 | Panasonic TC-32LX60 32 in. LCD Television
The signal select is set to analog but it still turns off when the volume is slightly turned up, can you tell me why?
Sounds like the receiver is defaulting to "protect mode", this indicates that there is an electrical short present in the system, I have found that speakers or speaker wires tend to be the cause often.
Disconnect all speaker wires at the back of the receiver, turn receiver on and raise the volume control and see if the receiver still shuts down, if the receiver doesn't shut off, then one of the speakers or speaker wires are bad, reconnect one speaker at a time, raise volume and see if the speaker you connected causes the receiver to shut down, if not continue connecting the speakers one at a time, testing to see if the receiver shuts down after each speaker connected, when the receiver faults to "protect mode" again after you have connected a speaker then you know that the last speaker you connected is the "blown" or shorted speasker or wire.If the receiver still shuts off after disconnecting all speaker wires, then either one of your sources has a problem(DVD,CDplayer,cass deck,etc.) or the receiver has an internal short that will have to be repaired by a servicer.
Good Luck !
Feb 14, 2010 | Pioneer VSX-D412 Receiver
Why does my stereo shut off when I turn it up it
Check your speaker connections, make sure wires are not touching each other. If this is ok, then check your speakers with a meter for an internal voice coil short. (blown) If you don't know how to use a meter, take your speakers to a local "Radio Shack" or electronics shop and they can test them very quickly. If wires and speakers check out ok, you have an internal problem with the system and it will need serviced. Hope this helps.
Sep 26, 2009 | Aiwa NSX-A777 Shelf System
I TURN IT ON AND IT SAYS CHECK SPEAKER THEN SHUTS OFF (2)
If you do not have any speakers connected to the unit and it still says "check" it's an internal problem and needs to be serviced or replaced.
Aug 14, 2009 | RCA RT2280 System
Just shuts down, then wait about 5 min. then turn off then on and it's OK -Totally random. Does not appear to be a heat problem
These units have a protection device that will trip an internal breaker and shut off to prevent damage. This feature will function normally if: 1. the volume is too loud. 2. You have a stray wire touching either metal on the unit or the wire from an adjacent speaker. Check all of your speaker wire connections. Also, it can't hurt to make sure that the speakers are all properly phased (+ and - connections are consistent on all speakers.)
As an afterthought, I've seen this happen too if the wires are too long or if there have been multiple splices. When the amp cant push the speaker and is overworking itself, the breaker will turn off.
Apr 19, 2009 | Koss KS3102 System
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
I Have a PIONEER PREMIER DEH-9600 MP. THE STEREO TURNS ON BUT THERE IS NO SOUND COMING OUT
Make sure there is no speaker in the system that is grounding to metal...this will cause the internal amplifier in the unit to shut off to protect itself from shorting. you can confirm this by disconnecting all speakers from the unit and one by one connecting them back up until it shuts off again or better yet, using a voltmeter, you can check for a shorted speaker contact or shorted voicecoil.
Aug 10, 2008 | Pioneer Car Audio & Video
Blown internal sony tv speakers
in menu(button on remotr) ,,scroll right to audio ..scroll down to speaker and turn them off!
Jan 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
