Question about Sharper Image Vacuums
Evac Where can I get a battery pack? Haven't used it for a long while because the batteries wouldn't charge anymore and just forgot about it until I stumbled over it the other day. Can I still get a battery pack for this item or should I toss it? Money wasted because I hardly used it in the first place. Thanks for your help.
3 Suggested Answers
SOURCE: Battery charge
Dave you are correct. You should never over-charge anything like a Roomba, Cel Phone, etc. That will kill a bettery very quickly.
Posted on Jan 11, 2009
sebano79
SOURCE: I need a user's manual
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Posted on Dec 27, 2011
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Irobot roomba 500
If you're sure the battery contacts are clean and the battery really is charged, then there is faulty circuitry within the Roomba that would have to be repaired or replaced.
Confirm that the battery is inserted with the metal contacts down so they make contact with the spring terminals in the battery compartment.
Visually confirm that the metal contact plates on the battery pack, and the spring terminals in the battery compartment are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
Visually confirm that the metal contact plates on the Roomba, and the spring terminals on the docking station's home plate are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
If you have a volmeter, measure the voltage between the contacts on the battery pack If it isn't something in the neighborhood of 14 volts and is 11 volts or less, the battery isn't fully charged.
Reinstall the battery.
For the moment, please connect the power adapter directly to the Roomba rather than the docking station to eliminate one possible faultly connection.
If the battery wasn't fully charged, or you weren't able to test it, try to charge the Roomba and then retest the battery voltage if you can. If the battery voltage was higher immediately after charging, but didn't get to 14 volts, the charger is good, but battery needs to be replaced. If the battery voltage was unchanged after attempting to charge the Roomba, the charging circuitry may be faulty. If there was no light patterns when you tried to charge it, and it was plugged in to a good outlet, then the power adapter or charging circuitry is definitely bad.
If you have no voltmeter and you cleaned the contacts and tried to charge the Roomba and it works, use the Roomba and then recharge using the docking station and see if it was just dirty contacts or it won't charge through the docking station. If it didn't work, you'll need to figure out if its the battery, the charging circuitry in the Roomba, or the power adapter. If there are no lights when you try to charge the Roomba, then Either the power adapter or the Roomba power circuitry is defective, but without a voltmeter you can't find out which one, and there's no way to know if the battery is good or bad, but you know Roomba wasn't trying to charge it. If there are lights when you try to charge the Roomba, then at least you know the power adapter is good. Unfortunately, without being able to test something there's no way to distinguish between a charger that won't deliver a charge to the battery and a battery that won't accept a charge. If you want to take a guess then a bad battery is more common and less expensive to fix.
Jul 07, 2012 | iRobot Roomba 560 Robotic Vacuum
Wont charge
Probably the battery pack is worn out or has a "memory" problem. A worn out pack will have one or more cells shorted internally (one or more cells read 0 Volts, and an ohmmeter reads less than 1 Ohm when connected to the 0 Volt cell). If it is a memory problem, it is possible to recondition it, but not simple. You have to remove the pack, then connect a 150 Ohm resistor across each cell and let the battery sit until the cells are completely discharged. You can't just connect a resistor across the entire battery pack because the stronger cells will reverse-charge the weaker ones, which will cause them to short out.
Running the battery too far down will cause the reverse-charge problem, but not running it down at least occasionally will cause the memory problem. (Memory problem explained: the cadmium crystals grow when the battery is charged and shrink as it is discharged. However, the larger ones tend to remain intact on discharge and grow faster than the smaller ones. Eventually they block the ion flow through the battery, so the battery loses capacity. It's called a memory effect because the battery only "remembers" it has the capacity to go down as far as it is habitually used. Running the cell all the way down dissolves the over-sized crystals.)
It is possible you have a problem with the charger. Check for voltage on the charger plug. It should be about the rated output voltage printed on the charger box before messing with the battery.
Apr 23, 2011 | Dirt Devil BD20035 Bagless Stick Vacuum
I have an Acuvibe 6002 messager with a Sanyo kr-1300sc 3 battery pack. It will no longer hold a charge. Where can I obtain a replacement pack?
I had the same problem. I found a replacement battery pack at Battery World Center 1032 E. Main St., Alhambra, CA 91801
626-576-8166
They replaced it for me for a total cost of $20.
Not sure where you are from. Hope they can help you. Maybe you can ship it to them for service? Good Luck. I love my Acuvibe 6002. There is nothing else like it anymore.
Feb 20, 2011 | Vacuums
I have a 2 year old Electrolux ergorapido cleaner that gets used daily for about 2/3 min, the blue light on the stand comes on when the cleaner is put on to charge but fades after about 5 min & the...
No, not worn out batteries.
For my experience, if the batteries were worn, they would charge with the blue led being on and after that, the vacuum wouldn't hold his charge. just that.
This is a different problem. Check the contacts between the charging station and the vacuum, mines got bent a bit and stopped making contact. This has happened twice and just fixed it about 30 min ago. That is why the led first lights and then goes off, there was just a brief contact between them.
Nice vacuum, very powerful and handy but maybe it is just poorly made as it is engineered in Sweden but built in China.
Jan 21, 2011 | Electrolux Vacuums
How to replace battery for PHV1800 type 1 18vdc
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Roomba Discovery SE Bagless Robotic Vacuum: My Roomba battery charger has no lights and does n...
use a multimeter to test if it is actually putting out a charge. Is this a regular roomba charger with the green led on top? And it just doesnt light up anymore? If so then the pack is dead. replace it.
May 16, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
I own a Sharper Image eVac. It came without a manual. I know how to use the eVac, but I want a manual. Do you have any suggestions? The Sharper Image went out of buisness long ago, so I can't get a manual...
I just got a eVac from craigslist today 12-22-09. Fairly new only been run a handfull of times maybe. This came with a manual but theres not much to it. (15 pages) It is supposed to run about 45 min to a charge and its good to let the battery run all the way down before recharging.
I got a half hour runtime after a couple shorter runs that didnt hold charge very long or didnt run becuse there was a brush sensor error.
I believe these types of batteries are best stored for long periods with some charge left on them, otherwise run it down all the way before charging. Manual says battery temp is a factor in how long it takes to charge, im guessing hotter = longer.
Filter is cleanable with water. No detergent. Fan can be air dusted clean too.
These are my findings after 1 day.
This one didnt want to go on carpet very long before stopping with a "brush error". The 5 small screws that hold the black plate with the red brush sensor window that is directly above the brush comes out easily and exposes the brush sensor in the middle which is quite fragile but can be air dusted clean.
A magnet is good to have on hand, the screws are tiny. With the plate off, I also gently aligned one sensor to be slightly more parallel to the other. This also helped reduce the brush error.
Note which side comes out first because it will want to go back in the same way it comes out. If forced in, this is where you can potentially bend the sensors and undo your careful adjustment and cleaning of them, This is the most critical step so take it slow and have plenty of light to see that no sensor gets pushed askew. Its like Operation The Wacky Doctor Game ...in reverse, dont touch the sides of the window to the sensor...bzzzt!
Dec 13, 2009 | Sharper Image Vacuums
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
Vacuums Logo
14 people viewed this question
Top Sharper Image Vacuums Experts
Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
