Not powering up. Fuse not blown, no power coming out of SMPS. PSU board details: SUNS JEP0800P-R0 VER1.0 94V-O
SOURCE: CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
SOURCE: PC smps power supply problem
ok you open the pcb check the fuse first then replace it if faulty if it burns again then check 4 diodes then see if 200v big capacitor is expanded or not if so then replace it if not then check diodes after transformer if short then replace it
SOURCE: Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
SOURCE: MLT386X power supply
We have a page with pictures and descriptions on this supply.
Hope it helps!
http://www.findonefindall.com/toyota-sienna/LCT37SHA_Scott_Akai_LG_LCD_tv.htm
