2002 Toyota RAV4 Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removing interior door panal w/o breaking it
Trying to replace a side view mirror on a 2002 RAV4. How is the inside door panel removed? Ive removeed all visable hardware but it just seems to be attached some how still
Anonymous
Level 3:
  • Master 1,986 Answers
  • Posted on Sep 29, 2009
Anonymous
Master
Level 3:
Answers
1986
Questions
0
Helped
1298738
Points
14923
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
Describe how to replace 2002 driver side mirror
remove the left door panel screws by inside handle and remove the 2 big screws in the arm rest may have some covers on it then with the panel clip tool or screw driver you need to hit the inside top of the panel as you lift up with you hand dont break the panel. carefully remove the door panel clips to release the panel. remove the screws inside the door at the mirror unplug the connector have someone hold the mirror so you dont scratch the car. then pull it loose and reverse the prosess.
1helpful
How to replace Inside Rear View Mirror on 2000
Hello, to replace the rear mirror, try the following:
1. Roll the passenger side door window all the way down. Turn off the ignition and remove the keys.
2. Gently pry the window control panel from the arm rest with the pry tool or screwdriver starting at the bottom of the panel. Flip it over and unplug all the wire harness outlets from it. Set the panel aside.
3. Locate and remove the two panel door plugs near the arm rest concealing the two screws and remove the screws with the Phillips head screwdriver.
4. Remove the door panel retainer plugs along the edge of the door by pressing in the middle of the plug to unlock it and removing the plug.
5. Detach the mounting triangle from the upper inside door panel covering the side-view mirror.
6. Remove the door panel by lifting outward and then upward. Disconnect the speaker wire harness from the underside of the door panel and set the door panel aside.
7. Locate and disconnect the mirror wire harness.
8. Pull back the foam insulation from the inside panel covering the side-view mirror.
9. Unscrew the three mounting nuts from the mirror using the ratchet, extension and a socket. Do not drop the nuts into the door cavity.
10. Pry the mirror gently away from the outside of the door.
11. Install the new mirror and replace the mounting nuts on the mirror studs and tighten with the ratchet, socket, and extension. Plug the mirror wire harness back in. Replace the foam insulation. Replace the mounting triangle.
12. Replace the door panel by reversing the procedure. Start by plugging in the speaker wire first.
Thanks
1helpful
I need to replace the Passenger rear view mirror on a 2002 Chevy
Use a long flat head screw driver with electrical tape wrapped around it(to prevent scratches). Have some one help you and hold a light so you can see the snaps on the inside, be really nice about it and pry the panel from the door frame.
2002 Toyota Rav4 remove door panel
There are some hidden screws around the door handle but you get under the panel and yank hard to pop the fasteners. Also remove the black piece behind the mirror. Alot of times it is seperate. 3 screws behind that and the connector and you are done.
5helpful
2answers
Side View Mirror Installation instructions needed
For a 2005 Honda Pilot, I am a complete Amateur and I had no problem installing this mirror.
1) Lower the window, and only remove the Interior MIRROR panel, NOT the entire DOOR Panel, as some sites my recommend.
2) Once the Interior Panel is removed, the power cable is attached to the mirror, remove this cable.
3) There are 3 Bolts that are BLACK (atleast in my vehicle) that need to be removed.
3) Once the bolts are removed, the mirror should come off easily.
4) Place the new mirror in place of the old one and secure all three bolts, and then secure the power cable.
5) Then place the interior panel back.
That is it!
1helpful
How to remove side view interior mirror control switches
You need to remove the door panel. there are 2 t-25 screws behind the pull handle (some models do have only one screw) as well as you must remove about 9 push buttons. then the door panel will pull away from the door itself then you can get to the mirror switch
3helpful
Replace Passenger Side Mirror on 2002 Ford F-150
5helpful
Replace 2007 Toyota Rav4 super sport passenger side door mirror
3helpful
2answers
I need instructions on replacing driver side rear view mirror on 2003 chevrolet monte carlo
7helpful
Side mirror of 2005 ford explorer
Exterior Mirror Removal and Installation
All vehicles
  1. NOTE: Left side exterior mirror shown, right side similar.
    Remove the interior door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel Removal and Installation
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the inside door handle bezel from the trim panel.
  1. Remove the window switch assembly.
  1. Disconnect the window switch and power door lock electrical connectors.
  1. Remove the upper trim panel screw at the window switch opening.
  1. Remove the lower trim panel screws.
  1. s2n~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, do not pull directly outward for this step.
    Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  1. Disconnect the power mirror electrical connector.
  1. Remove the trim panel.
  1. Remove the weather shield.
Vehicles with power, heated or approach lamp equipped exterior mirrors
  1. Disconnect the electrical connector.
All vehicles
  1. Remove the bolts.
  1. Remove the exterior rear view mirror (17682).
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
