Question about Cooktops
Bosch ceramic hob NKT 62.L,PKE64.E
Not working 10 m/m red square appears after stand-by pad is operated no rings funtion
4 Suggested Answers
SOURCE: Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
Posted on Sep 15, 2008
meBNme
  • 334 Answers
SOURCE: brand new bosch pke691e20e ceramic hob trips 50amp mcb
You have a short to ground somewhere.
Was there a new cord installed on it or did the cord come already installed?
It could have been wired wrong causing a short to ground. there could be another wire touching the cabinet, a wire pinched by the cabinet.
You may have to trace down every wire with a continuity meter to find it, but its probably fairly obviose.
I'd start at the cord.
First try this, unplug the cord, turn the breaker back on just to make sure the problem is indeed in the unit not the receptacle or panel box.
If the breaker stays on, you know its in the unit.
Posted on Dec 06, 2008
BElectric
  • 1140 Answers
SOURCE: how to use the BOSCH PKE611E14E built in ceramic
Hello there,
Your best option would be to download the user manual for the cooktop and then let me know if you have any further questions. Please click on the following link to download the manual for this cooktop (in PDF format), direct from Bosch.
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=ujxuEojcdcso0pdmdb---HpZ&UMOBID=ujxuEoacdcso0pdmdb---HpZ
If you have any difficulty downloading or printing the manual or if you need further assistance, please let me know.
Regards,
BElectric
Posted on Mar 05, 2011
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
Mar 11, 2014 | GE Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob. I also have the red key about the on switch and cannot swithc it on!
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
May 28, 2009 | Neff 23 in. T4343 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Bosch ceramic hob
May 30, 2008 | Bosch 24 in. PIE675T01E Electric Cooktop
Cooktops Logo
185 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
