Question about Sony SA-WM40 Subwoofer
SPEAKERS PROBLEM THE SPEAKERS ARE NOT WORKING WELL BECAUSE THEY GIVE OUT FAINT SOUND(SOUND THAT CAR NOT BE HARD 1M AWAY FROM THE SPEAKERS).BUT I LATER DISCOVERED THAT IT IS THE PORT OF THE SPEAKERS THAT ARE HAVING PROBLEMS. PLEASE WHAT IS THE SOLUTION TO THIS PORT PROBLEMS
Faint sounf from car speakers
Just a couple general ideas. If it is a used car then the head unit is possibly failing. Another possibility is resistance building up at the connections. If you can clean the connections, plugs and slipons with electronic spray, erasure, and fine sand paper if accesable.
Mar 20, 2014 | Audio Players & Recorders
What is the best way to set up my 5 inceling speaker system room size is 18x15 TV is centered on 15 ft wall 10ft ceiling ?
place your subwoofer approx 1m or 3 feet away from your media player, then one speaker below your TV, the other two in either corner in the front and the other two in either corner at the back of the room. try not to mount them too high, approx 3 feet off the ground or the same hight as your head when seated. this will give you the best sound quality. if the speaker is the front or back seem a little far you should be able to set the volume on each of them. if the back is further than the front then set the back speakers louder than the front ones or vis versa.
Nov 07, 2013 | Denon AVR-3806 Receiver
DoubleDown was giving away 1m chipsto loyal players. I did the word gifts on the page where you buy chips and it gave me the 1m chips. I started playing and all of a sudden they took the 1m chips away and...
Zynga Poker sent you an email regarding possible unauthorized access to your Facebook and Zynga Poker account. This email was sent to a**a@yahoo.com. We recommend changing your Facebook password immediately.
Please verify your account by carefully following the instructions in the email. Click here to resend email.
Message Code: CA1
Aug 11, 2013 | Evermoremedia DoubleDown Casino
C370 faint crackling sound left channel
have you tried looking at your phono leads,turn volume down until it is low enough that you can still hear the music playing,give the phono leads a turn to see if its a loose connection.if not,try the right channel phono in the left channel to see if this fixes your problem.also you could do the same with your speaker leads and see if that solves the issue.maybe a bad connection is the cause?.it may also help to try and move your cd player away from your amplifier.it could also have been overdriven (played too loud for too long) on the night of the party,only you will know if this was the case or not.
Jan 07, 2013 | NAD C370 2-Channel Amplifier
My rear speakers do not conect further than 1m away from the main unit. How do I solve this?
you would have to get a sronger wireless device for the speakers get in touch with logitech to see if they have one.
Feb 19, 2011 | Logitech Z-5450 Computer Speakers
Connected 8ohm speakers with monster wire to banana clips.Turned on unit says check speaker wires I then rechecked and turned it on then no sound but I can faintly hear the speakers -50dbs hat gives?
You didn't mention >>>>> if it worked before you added the Monster cables and banana plugs <<<<<.
Nor did you say what you found when you checked the speaker wires. If you found nothing you still need to investigate further.
When you make a change and things go south you have to start UN-making the change to find out what went wrong.
Faint sound overall usually means a Tape Monitor or Mute function is active.
Feb 25, 2010 | Yamaha HTR-5830 Receiver
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
Wired remote cable extension
Most monitor cables have only 14 of the pins connected, but if you get a fully wired svga extention cable it does work fine.
Steve
Mar 23, 2008 | Logitech Z-2300 Computer Speakers
Bose cinemate acoustimass module
try taking ones apart that have the rumbling and see if theres anything loose inside
Jan 21, 2008 | Bose Cinemate Digital Home Theater System...
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
Sony SA-WM40 Subwoofer Logo
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
