Question about Safe International Hollon Safe 1.02 Cu. Ft. Data Safe
Digital Lock System for C E Lock.
I have a new Hollon Safe with CE Digital Lock system. I am trying to obtain the master code so that I can put my personal code into the new safe. It came with instructions but no "master Code" I can I obtain same?
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
SOURCE: I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Posted on Apr 27, 2009
SOURCE: change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Posted on Nov 28, 2009
SOURCE: Noble CE Safe Electronic
It´s very easy, you have look for a red button behind the door, press it for 3 seconds and the press the code you want and then press A. Hope you fix it.
Posted on Apr 23, 2010
  • 4 Answers
SOURCE: I have a Electronic Hardline Digital Safe. I have...
inside the safe door near the hinges there is a red button. Push it and the "proceed" light on the top right of the keypad will come on. enter your new code and "A". That's all.
Posted on Jul 12, 2010
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    Battery dead, can't find keys, is it possible to obtain another key? what info do you require if answer is yes.
    A locksmith should be able to pick the lock and make a new key. Manufacturer might have replacement keys, but you'd need either the key code or safe serial number.
    Jul 15, 2014 | Safe International Digital Electronic Safe...
    I need to reset my combination to my mesa safe
    This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
    If you changed the Master Code you will need to use the code you changed it to.
    Deleting your current User Codes:
    Input * - * lock will beep twice
    input 6-6-6-# lock will beep twice
    Input current Master Code - # lock will beep twice
    Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
    Re-input user number - # light stays green for 3 seconds
    Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
    This will delete user 5
    Unsuccessful code change: five beeps, repeat the steps.
    Changing User Codes: Code length can be 3 to 8 digits long
    Input 4 - 4 - 4 - # lock will beep twice
    Input Current User Code - # lock will beep twice
    Input User Number - #
    Input New User Code - # lock will beep twice
    Re-input New User Code - # light stays green for 3 seconds
    Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
    That example will change user code 2.
    Unsuccessful Code Change: five beeps, repeat the steps.
    There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
    The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
    Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
    My ce safe has flat battery. how do we open it, please advise Graham
    i have a CE electronic safe,batteries went,so i heated the lock with the hair dryer,it worked for me
    Jun 12, 2011 | Safe International Digital Electronic Safe...
    I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions...
    I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions from the internet anywhere? The keys have 128 written on them but I cannot find any further I.D numbers anywhere. Thankyou very much for your assistance
    May 21, 2011 | Safe International Digital Electronic Safe...
    I NEED TO RESET THE MASTER CODE ON THE GORDON DIGITAL SAFE BUT I DO NOT KNOW THE OLD MASTER CODE
    hi
    menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
    Apr 14, 2010 | Safe International Digital Electronic Safe...
    Change code
    Try this
    Open the safe.
    Should be good
    Nov 22, 2009 | Safe International Digital Electronic Safe...
    Master code setting couldn't do it (alarm system ADEMCO VISTA-10)
    hi
    Jun 14, 2009 | Eagle SeaChamp 1000c Recording Sonar...
    May 28, 2009 | Safe International Digital Electronic Safe...
    Safe International Hollon Safe 1.02 Cu. Ft. Data Safe Logo
    Top Safe International Home Security Experts
    Lawrence Oravetz
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Safe International Home Security Expert? Answer questions, earn points and help others
