Question about MicroPac Technologies MicroPac USBDVR4 4 Channel USB 20 DVR Security Surveillance CCTV Digital Video Camera Recorder Adapter
Honestech dvr2.5 everything works even taking pictures but when I start to record a video it has a box that pops up saying error in recording
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
How do you make it work in windows7
I found this on a forum....I hope it helps!
This review is from: VHS To DVD 4.0 Deluxe [OLD VERSION] (CD-ROM)
I needed a way to connect my PS3 to my PC so I can take some screenshots and I only had 2 days to do this so I searched Amazon for VHS to DVD's and this was the one the best rated products. Next I went to Honestech to make sure Honestech VHS to DVD 4.0 Deluxe was compatible with Windows 7, and it was. So I rushed down to my local Fry's Electronics to pick one up, price was about the same so no problem there.
Problem:
Once everything was installed hardware/software/drivers, I ran the Honestech software and after a few minutes of running my PC just locks up. So I rebooted and tried again, but again my PC locked up, now I am confused since they said it was Windows 7 compatible and I did get the latest software from Honestech site. I first thought it was my PC but after some testing I did discover that it was Honestech software that was locking up my PC.
Solution:
OK so here is what I did to make it all work, forget the Honestech software you don't need it. Go to Honestech site and get the drivers for "HT VIDBOX NW03" this is what comes with the Honestech VHS to DVD 4.0 Deluxe. Download and install the drivers and restart, go into Device Manager and make sure you are not getting any device conflict and that everything is installed right. On Windows 7 the only thing I saw that Windows 7 didn't have drivers for was the audio, so installing these drivers fixed that problem. Now Google Virtualdub, it's a free video editing tool, Open Virtualdub go to File and select Capture AVI. Now under Device go select your USB2.0 VIDBOX NW03 (DirectShow), you should now see video coming from your HT VIDBOX NW03 go to File and select Set Capture File, enter the file name you want your video file to be and where you want to save it and hit save. Now go to Capture and hit Capture Video to start recording, and it Capture Video again to stop recording, that's it you are done.
Jan 02, 2015 | Televison & Video
My webcam won't let me take pictures on face book and it said to reset,what does that mean.
Step 1:
Go to Facebook and log into your account. Click the "Profile" tab. Click the "Video" link in the "Status" menu. Select the "Record a Video" option. For privacy reasons, Facebook requests permission to access your webcam and microphone. Check the box next to "Allow" and click "Close." You will appear in real time on the Facebook webcam window. Position yourself in front of the webcam and click the red "Record" button to begin recording your new video. When you're finished, press the "Stop" button. Click the "Play" button to view your video. If you want to post it on your profile, add a brief message and click "Share." If you're not satisfied with the outcome, press "Reset" and record a new video. b> Video Message Log into your Facebook account Navigate through your friends list and select the friend you want to send a video message to on Facebook. Click the "Send Message" link in the upper-right corner of your friend's page. Click the "Video" icon in the attachments section at the bottom of the "New Message" window. Check the box next to "Allow" to give Facebook permission to access your webcam and microphone, and then click "Close." Press "Record" and record your new video message. Click "Stop" when you're finished recording. When you're finished recording, you can press "Play" to preview your video.
Feb 12, 2013 | Acer eMachines 520-2890 Notebook
How do i take a picture on my Toshiba laptop
1. Open a program called"Camera Assistant." This is a Toshiba-supported computr program designed specifically for people with cameras built into their laptops.You can find this by clicking on the "Start" menu and then navigatingto the "Programs" sub-menu. 2. Press the"Picture" button in the "Camera Assistant" program windowto take a picture using your built-in camera. This will take one stillphotograph for every time you click the button. The image you are taking willappear on the right side of the main program window. 3. Press the"Video" button in the "Camera Asst" program window tobegin recording video using your built-in camera. This will record video untilyou press the "Stop" button. The video you are recording will appearon the right side of the main program window. 4. If you can't open"Camera Assistant," reinstall your drivers. Though the camera on aToshiba laptop is designed to work right out of the box, if it doesn't you mayneed to reinstall the driver that makes it work. Look for the CD labeled"Drivers and Software" that came packaged into the box with yourToshiba laptop. Pop it in your laptop's CD-ROM or DVD-ROM drive and install the"Digital Camera" driver contained on the disc.
Nov 11, 2010 | Toshiba Satellite A105 Notebook
Help with Error message on DVD recorder
Hi, is there any problem with reading discs? Its happened only with one brand of disc or with all? Try to use the most silver one you can find. 3 years is a lot of time for dust to cover lenses, try to clean them up. Reset to factory settings and unplug device for some time can help as well.
Oct 13, 2009 | Televison & Video
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Cant record video-- keep getting error code
Never mind--- Just needed to restart the computer-- works fine now!
Sep 29, 2008 | Logitech Quickcam Chat Webcam
Nikon S6- LCD screen black
I have The same problem with my S6, and was wondering if you found a solution? Ive done everything but contact Nikon or a camera shop.
Apr 16, 2007 | Nikon COOLPIX S6 Digital Camera
MicroPac Technologies MicroPac USBDVR4  4 Channel USB 20 DVR Security Surveillance CCTV Digital Video Camera Recorder Adapter Logo
82 people viewed this question
Top MicroPac Technologies Home Security Experts
Lawrence Oravetz
Are you a MicroPac Technologies Home Security Expert? Answer questions, earn points and help others
