Question about Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
Get in service mode c6500
Light orange prints pink
Canon IP2600 Ink absorber replaced and i am still get the error message. I have been told that the count needs to be reset. this is done with a button sequence on the printer. Does anyone have this...
Try these:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Function Procedures Remarks
Service test print
- Model name
- ROM version
- USB serial number
- Waste ink amount
- CD-R sensor correction
See "Service mode operation procedures" below. Set a sheet of A4- , letter-, or larger-sized paper.
For print sample, see 3-4. Verification Items, (1) Service
test print, <Service test print sample>.
EEPROM initialization See "Service mode operation procedures" below. The following items are NOT initialized:
- USB serial number
- Destination settings
- Waste ink counter
- CD-R correction value
Waste ink counter reset See "Service mode operation procedures" below. If the waste ink amount is 7% or more, replace the bottom
case unit, or the ink absorbers.
Destination settings See "Service mode operation procedures" below. Other than Japan: iP4000
Japan: iP4100
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage returns and locks
in the home position.
1 time Orange Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green EEPROM information print See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the Destination settings
procedures.
6 times Green Print head deep cleaning
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal) Not used in servicing.
9 times Green CD-R print position correction
(vertical) Not used in servicing.
Hope that helps!
Jan 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
Cant use
Try this steps Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
The number of the Reset
button pressing
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 07, 2009 | Office Equipment & Supplies
My iP8500
Service mode operation procedures>
in green to indicate that a function is selectable.)
Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
4) When The LED lights in green, press the Resume/Cancel button the specified number of time(s) according To the function listed in the table below. (Each time
the Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
completes, the printer returns To the menu selection mode automatically.)
<Destination settings procedures>
in the destination settings mode, press the Resume/Cancel button the specified number of time(s) according to the destination listed in the table below, and press
the Power button.
Note: After setting the destination, confirm the model name in service test print or EEPROM information print.
[See 3.4. Verification Items, (1) Service test print, or (2) EEPROM information print.]
To the top
Time(s)
LED
Function
Remarks
0 times
Green
Power off
locks in the home position.
1 time
Orange
Service test print
2 times
Green
3 times
Orange
4 times
Green
5 times
Orange
Proceed To the step 5), and follow the destination settings
procedures.
Destination
1 time
Orange
Japan: iP8600
2 times
Green
Other than Japan, non-support of CD-R printing (A4): iP8500
3 times
Mar 25, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon printer mp150
can you try to reset, here are the steps
Mp150
Reset Counter
button pressing
procedures below.
procedures below.
Feb 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Service Mode
need to down load software for mp150 printer
Feb 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
How to reset wasted ink counter
Mp150
Reset Counter
button pressing
procedures below.
procedures below.
Nov 22, 2007 | Canon PIXMA MP150 All-In-One InkJet...
ERROR ON MY CANON PIXMA MP150
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Oct 31, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Service Error with my cannon printer 160
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Stupid printer
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Sep 26, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Konica Minolta Bizhub Pro C6500 Color Copier Color Printer Logo
49 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
