Question about Car Audio & Video
Kenwood pojacalo KAC-7020
Koliko je jek wati ovaj model
  • 631 Answers
SOURCE: kenwood KAC-PS201T
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 22, 2008
zzedly
  • 300 Answers
SOURCE: kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Posted on Mar 13, 2008
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
wikkidd420
  • 96 Answers
SOURCE: want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Posted on Jun 11, 2009
  • 136 Answers
SOURCE: connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Posted on Sep 03, 2009
Koliko ulja ide u motor
Bok, Anonymous Kapacitet motornog ulja 3.5 ml za ovaj scenarij , trebat ?e vam va?e usluge / vlasnici priru?nik , ako ne mo?ete prona?i prvi i najbolji alat li ikada kupili za svoju Yamaha, o?aj ne, za samo $ 0 mo?ete preuzeti jo? jedan , Za vi?e informacija o svom problemu i vrijednim "slobodni" preuzimanja koja ?e vam trebati kliknite na linkove ispod. Sretno i lijep dan .
XJ700X Specifications
Oil change on 85 Yamaha Maxim XJ700NC
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 07, 2013 | 1986 Yamaha XJ 700 X Maxim
Remote controle daljinski problem
http://www.google.ba/url?sa=t&rct=j&q=philips%20saa7130%20tv%20tuner%2Ffm%20radio%2Fvideo%20%20manual&source=web&cd=11&ved=0CCkQFjAAOAo&url=http%3A%2F%2Fmypdfmanuals.com%2Fuser-manual%2CPHILIPS%2CSAA7130%2C708856.pdf&ei=BMgUUYmTMsbEsgbQyICgDg&usg=AFQjCNH6n4tEdpQFf879ayWSd6q9mqeuZg&bvm=bv.42080656,d.d2k evo uputsvo pa vidi nesto nisi dobro podesio ako neznas jezik onda ovaj link kopiraj u google translate i prevedi na koji hoces jezik
Jan 23, 2013 | Philips SAA7130 TV Tuner/FM Radio/Video...
XM-2165GTX Car Audio Amplifier: i have a kenwood 1000watt amp model # kac-7204 i h...
I would try to remove the top cover of the amp and you might be able to push them out from the inside. Just a shot in the dark.
May 16, 2010 | Sony XM-2165GTX Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Hello laurogleal,
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Kac-ps201t problem
I had a similar problem with a KAC-X812D Kenwood amplifier.
My problem turned out to be that the RCA inputs were so sensitive, they picked up interference from my head unit through the RCAs.
I replaced the head unit with a newer model, and had no problems after.
This may not be your case, but hope it helps.
Dec 15, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Probems with my kenwood 7020 amp
The ground nearest "batt" connection is your main ground. The other "GND" is for grounding shielded RCA cables.
If the amp is being used to run subs alone:
  • Set the Bass Boost to 0.
  • Set the LPF Frequency to about 80.
  • Set the Input Sensitivity to 5 (the minimum).
  • Set the Filter to LPF.
If things sound fine at these settings, one at a time, slowly bump the Bass Boost and the Input Sensitivity up, checking the sound quality as you go.
Mar 31, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood manual
Here is a free manual, just download it.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e73fb2d3135db11ba752b002abe6f643&q=Kenwood+KAC-748
Oct 30, 2007 | Car Audio & Video
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
